OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
#3579
CA
RE: OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
ORIGINAL: madmax22
danju thats a good idea! think the stock electronics can handle it?
the lipo will fit on the top deck. electronics will be above it.
but im having troubles getting a good charger[&o]
..need to convince pops
#3583
ORIGINAL: CrazyEh
Here's a picture of my new Mirco DT... picked up some new wheels today!
any suggestions on making them stickier or other tires?
#3584
PA
my DT tires grab like mad on wood floors, try putting WD-40 on them let them dry they will gip so good its not even funny...
#3586
I'm going to get a Micro-T from one of my friends for VERY cheap and then convert it to a DT. After I play with it for a while I'm going to get BL and Li-Po for it. I just wish that they made a smaller Receiver for my Futaba FASST Radio.
#3587
PA
Joe im using grease.... My tranny is very tight though maybe ill put some motor lube in there its still new so that could be the problem...
#3588
The tires don't grip worth crap outside... since I only run mine outside, I have no idea how it'll handle inside.. while they do look awesome, like I said, they don't grip at all outside.. ended up putting the stockers back on.
#3589
Any alternatives to the $$$ Losi Lipos? How about higher mAh Nimh? Also, where can I get the Losi micro connectors?
Thanks!
Thanks!
#3590
TX
HEY GUYS
got a simple question. recently bought the losi MICRO BAJA a week or two ago. found a few videos showing to decrease the slip to gain the extra "power" getting lost with the stock slip setting...
diagram of exploded parts/manual : check
socket for the 4.5 mm nut: check
turned the nut a few times. nothing different. same amount of slip. tried backing it off a turn or so. no different result. i then (because i have the exploded view of parts in hand) removed the nut, and carefully dumped the parts on a towel. had i known there were addtional blue o-rings and washers not shown on the diagram, i wouldnt have dumped them out.
can any of you provide a pic of an exploded view in order ? the tiny parts in front of the spur gear are visible in the diagram, but the parts behind it are NOT shown..so i now have no idea how they go back in. i have an additional blue O-ring, and another 2 or 3 washers that were behind the spur gear. is it mirror image to the parts in front?
thanx
#3591
AL
Here is some pictures I just made of my micro T I converted into a DT. Hot pink paint job so my wife wouldnt get so pissed about me blowing the money. I didnt like the look of the red parts of the decals that came with the body. Red and hot pink dont match too good, so I cut the red parts out of the decals then put them on. Turned out pretty good.
#3592
PA
sweet body, imma pick up a clear body for my micro-t and paint it black. i gotta get micro deans anyways.
#3593
CA
im thinking about getting two areonuts lipo batteries and charger, rear aluminum hubs, and some of the silver threaded rear wheel shafts...
now are those silver threaded wheels shafts worth the money???
here they are
http://www.thetoyz.com/cart/thetoyz_...name=MICRO%20T
here they are
#3594
PA
I wouldent bother... Just get the regular threaded shafts... can you send the link to the aero nuts lipo's imma get 2 or 3.
#3595
CA
max22, i believe maxxin is talking about [link=http://www.aero-nuts.com/product_info.php?products_id=433]THIS [/link]
#3597
CA
yup those are the ones... and they have a 15$ charger im gonna get if you look under lipo chargers...towards the bottom..
and the reason i want the wheel shafts is because i broke my rear hub and lots the dogbone soo im thinking of just buying the wheels shafts...idk..i might just get a bunch of stock hubs also and a bunch of stock dogbones...mine get bent real easy...
also do lipo bateries make a HUGE difference..i mean i have raminator wheels and i dont really like them all that much...my micro flies maybe 20+ just with the stock nimh bb motor and raminator wheels...and it flips on corners with the raminator wheels..
i might just buy some more foams from thetoyz becausethose foam are really nice...grippy and barely even wear down...ran them for three days nonstop practically and almost no wear...justa couple little dents...
#3598
PA
HUGHE differnence.....my lipo connectors broke off and i put the nimh back in.... man what a difference.... my friend was over with his and he had a lipo i had the nimh... it was stupid how much faster his was....
#3599
CA
ok that sounds like what i want...
none of my friends are into rc which sucks...just trying to get my neghboors that used to be really big in it back in...
i am buying all this fancy stuff...like mini 1/16 nitro 1/16 brushless 1/34 lipo and aluminum...
haha i hope they will buy at least one more so ic an race them and stuff...
there are no tracks around here either...
sonim just left to play alone... []
#3600
PA
yea i know about 2 people that are or were into it... he lives inNJ and has a weekend or summer house in PA here and we always hang out, ride quads, wakeboard, skateboard anything.... He has a micro-t and a t-maxx 2.5 with a 3.3... we always fool around and get the old people P.O'd[sm=lol.gif]
