1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
List your Micro-T Problems
Reply
Old 02-13-2007, 08:09 AM
  #51
ILoveMinis
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: List your Micro-T Problems
that sukcs hmmmm.....
maybe your gears are a little tight.
how hot is the motor running?
ILoveMinis is offline
Old 02-13-2007, 11:56 AM
  #52
MaximuM*AltitudE
MaximuM*AltitudE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just picked up my Micro-T two days ago and it is a great little truck! Only thing I have done so far is put Xmod Evo truck springs on it to make the suspension stiffer. Red on front, Yellow on rear. Now it doesnt bottom out and slam the chassis into the ground. Next will be some bearings a battery and a hotter motor. Fun little beast!
Mine would also not pop wheelies, but tightening the diff provides some great wheelie action, it just doesn't turn for shizzle on the carpet.
MaximuM*AltitudE is offline
Old 02-13-2007, 12:05 PM
  #53
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the same springs only I put the yellow on the front and the red in the back.
t9dragon is offline
Old 02-13-2007, 01:21 PM
  #54
blazew0n
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well , my problem solved itself somehow, no more 180's. I'm amazed at how quick my micro t is stock. Only thing i have on it is the bearing. It's just so agile and quick. I'm easily wheeling 10-15 feet on carpet. i would love to race someone elses T just for comparison. Def. great entertainment. Is there a way to tell if your spur gear is not working? i adjust mine but see now difference with the slip at all.
blazew0n is offline
Old 02-17-2007, 11:59 PM
  #55
ILoveMinis
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hmm. just take the whole thing off and put it back on again. maybe one of those little blue grommets creeped behind.
also, with the xmod evo truck springs, wouldnt it make sense to put the red in the front because there softer? im not dissin your personal preference or anything.
Old 02-26-2007, 08:45 AM
  #56
ub0211042
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
I just got my micro-t today, my only problem with it is i feel that the response is little slow.
Example, when i hit the throttle it takes like a few milliseconds for it to react..
Feels like there’s a lag. I own few mini-z and the response is a lot faster.
But the steering response is fast but the throttle is not.
Is it normal?
Thanks.
ub0211042 is offline
Old 02-26-2007, 01:25 PM
  #57
blazew0n
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
break in your differentials, hold one rear wheel in your hand with the with the other hanging in the air and with your remote, give it some throttle, not too much though for about 15 seconds. than do the other wheel. do it for 1 pack for your battery with breaks in between so you don't melt the diffs. also loosen the screws around the tranny case.
blazew0n is offline
Old 02-26-2007, 07:19 PM
  #58
clutchbob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My problem is that I have only one of them.
Quote:
few milliseconds
.004 seconds isn't fast enough for you?
clutchbob is offline
Old 02-26-2007, 08:46 PM
  #59
ILoveMinis
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lol. nice
Old 02-26-2007, 09:42 PM
  #60
ub0211042
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ermmmm make it about 1 second haha...maybe i have to loosen up the diff...
Quote:
ORIGINAL: clutchbob
Quote:
few milliseconds
Old 03-12-2007, 08:39 PM
  #61
neightfrog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have had my micro t for 5 days now and i have broke the tie rod and the rear hub carrier, mostly from jumping it off of stuff that is way to big for in, but my main problem is charging the battery. my charger works fine and and so is my battery, but if i forget to turn it off it wont take a charge. i had to tske it to the hobby shop and use their triton charger. it kept on charging but then i left it on and wont charge, aggravating.
neightfrog is offline
Old 03-12-2007, 11:09 PM
  #62
makg
makg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So, don't leave it on and unplug the battery after every use.
makg is offline
Old 03-13-2007, 04:07 AM
  #63
ub0211042
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm having problem with these battery i just bought from ebay:
5 X 3.7V 160mah 4.2gram Lipo.
for Micro R/C Plane
Item no. BLB37V160M
Description :
Discharge rate : 600mAh (Max800mAh)
Li-battery 3.7V normal 4.2V fully charged, 160mAh
Length: 3.5CM
Width: 2.0CM Height:0.35CM Weight : 4.2 gram
The problem is with 2 cell li-po, my micro goes slower than when using stock battery.
What could be the problem?
I've also ordered some of this http://www.all-battery.com/index.asp...OD&ProdID=1639
but kinda afraid that same problem might occur.
Could it be not enough "punch" from the battery?
Old 04-03-2007, 11:27 AM
  #64
mgt guy24
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i didnt really have that many troubles but i have some good tips like i treid mine on carpet and the strings got wound up in the drive shaft so i had to take the tires of to get to it snd i lost the clip that holds it on so i took a bread tie and pealed the paper off of it and i twisted it tight and cut it its ten times better than the clip and will hold for a long time another thing is people told me to put zip ties on the shock so the would be stiffer but i didnt want to do that so i took the springs off nad replaced them with fuel line i will have pics on l8r
mgt guy24 is offline
Old 04-03-2007, 11:36 AM
  #65
mgt guy24
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
but i have a ? i want to put a spectrum 2.0 in my micro t but i dont no how cause the esc and the reciver are the same unit so i dont no what i would have to do ????????
Old 04-03-2007, 12:56 PM
  #66
kyle1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
easy...buy a new ESC, i think thats your only option
kyle1 is offline
Old 04-25-2007, 08:03 AM
  #67
Kloft
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys, so do you think after all these problems the micro t is still wort gettin, and i know that atomic makes really good hop ups and parts but what kind of hop ups would i be able to find at my lhs?
Kloft is offline
Old 04-25-2007, 10:00 AM
  #68
BOBCAT45
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am new here and bought a micro last week, like this truck. No problems yet runs good ,charges good. Can a guy put ink pen springs on the shocks to stiffen them up a little, i was thinking of doing that because the stock springs r a little spongy. Any suggestions would be apreciated, also i sent off for a wheelie bar that little thing pops good whellies on the carpet! I ordered it from www.killerhobbies.com they have a lot of hop up parts for the micro t and r real good people, check out there web site, and there prices r not bad either. Could a guy do two charge cycles and get a little more run time? I am averaging about 10 minutes per cycle. Let me no something guys. Later
Bobcat45
BOBCAT45 is offline
Old 05-06-2007, 07:50 AM
  #69
jonhoffm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just picked it up yesterday. The transmission was binding, but not uniformly. First thought was the pinion-spur mesh - no joy. Took the trans. apart to see that the shaft connecting the spur to the trans was bent slightly causing it to bind up a bit as it rotated. I believe that it is binding up the trans gears (as opposed to rubbing against the trans casing). The truck will run for a few minutes and then shut down - I am not sure if it is the engine overheating or the esc, not that it matters. Anyway, it looks like I will have to talk to Losi about it. Bummer.
jonhoffm is offline
Old 05-06-2007, 08:15 AM
  #70
nitro _ burner
nitro _ burner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys i have been having some trouble with my micro t, i have narrowed it down to those little brass gears inside the diff, i think there worn down too much probably from running it too much but anyway i can eaisly fix that, but my spur gear has a bit of play in it, has anyone else expereienced this?? I think i might buy a new complete trans just too be shure.
nitro _ burner is offline
Old 05-27-2007, 11:25 AM
  #71
boohoo
boohoo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mines wont charge or run motor when i do get it to chatrge
boohoo is offline
Old 05-27-2007, 07:39 PM
  #72
poomaster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
get the losi lipo and you can get 30 min run time with insane power had mine since monday have toasted 2 diffs though nasty power now
poomaster is offline
Old 10-08-2007, 07:42 PM
  #73
Dalton2510
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
try putting brand new batteries in the charger i thought mine was broken to READ THIS IF U HAVE HAD YOUR MICRO T FOR ONLY ABOUT A WEEK OR TWO CALL TEAM LOSI AND TELL THEM YOUR BATTERY CHARGER DONT WORK THEY SAID IT WASNT THE CHARGER AND IT WAS THE BATTERY SO THEY SENT ME A FREE BATTERY!!!!! only shortly after i found out that it wasnt neither charger or battery it was my batteries in the charger u only get about 4 charges off of 8 batteries ANYONE WHO HAS A MICRO T SHOULD CHECK OUT this charger mod it works i did it http://www.ripper7racing.com/r7rforu...read.php?t=458 and its fairly cheap
Dalton2510 is offline
Old 10-09-2007, 06:10 PM
  #74
coreybates17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i had the turn rod problem....i also some how managed to strip out the pinion gear i think...... (it doesnt come off) and suggestions?
coreybates17 is offline
Old 10-23-2007, 02:50 PM
  #75
Metallover
Metallover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I say definetly get the losi lipo battery and charger. It plugs into the wall and gets 30 min of run time and a lot more power.
ub0211042, the batteries you got dont have any power because they are 3.7 volt. Stock is 4.2 i think and lipo is around 7.
My tie rod broke and I am going to try to get aluminum ones.
LOVE IT!!!!!!!!
EDIT-I am selling it. I want a kyosho half-eight
Metallover is offline
Reply
Display Modes
