Quark pro 33a esc?
Quark pro 33a esc?
how many volts can it handle? and how many cells can i run? i may not have the money for a lipo system so i may have to go back to plane nimh packs!
RE: Quark pro 33a esc?
what nimh pack will gime me the speed of a 3s lipo maby a 9.6v pack? http://www2.towerhobbies.com/cgi-bin...?&I=LXHHU6&P=7
Even if you match voltage, lipo has less internal resistance. This definately gives the batteries more punch. And like someone else stated, li-po is lighter.
well right now i'm running a plane sub c 7.2 pack with hard springs so it does'nt bottom out and it takes xmall jumps well. i was gonna use these: 2 of these one on top of a nother, Venom Micro 7.2V 1200mAh NiMH 19.99 only ways about 4oz per pack besides i need weight oter wies how am i gonna keep it on the ground?
If you want real speed and handling I would try to get yourself one of these chassis. They are the team bluegroove chassis and are a bit longer than stock. I run a 3 cell lipo and a 8000 motor and the front stays down very well.
i use to use this pack in my mini giant and i would get about 15min run times, as u can see in the pic thered room for 2 of these: there 7.2v 6c 300mah packs!
I'm not sure if they are still making them. I bought the last one they had about a year ago. They might have made more by now. They were around 80.00 for the chassis.
