mini lst run time help
GA
My mini lst's little run time run time (7-8min) is finally getting to me. I just rebuilt and lubricated the F/R and center diffs and checked for grinding and the run time didn't have any noticable increase. Does anyone have a clue what the problem is, or any suggestions? Thanks.
NY
GA
RE: mini lst run time help
Yes Racing T it is stock.
Zach, thanks for the suggestion, but for now, im dont want to buy a lipo because then ill have to buy a charger, and i dont have enough money for bouth right now.
NY
what charge rate do you charge at? if it is to high(over 1.5) you might have ruined the pack and thats why.
a good alternative to a lipo is a team orion 1600
http://www2.towerhobbies.com/cgi-bin...?&I=LXMEY4&P=7
I have one and it gets about 15 min.
this is again probably out of your buget but save for a low kv brushless motor, that will bring your run time up.
a mamba 4200kv and that 1600 will get 20min
Something is wrong. My Mini LST is mostly stock and I get 15 to 20 minuets of run time. What charger are you using? I would suggest that you get a nice peak charger.
GA
Inverted and Dokioto, i use a Duratrax IntelliPeak pulse charger.
Zack, i've already started saving for one
and Racing T i checked and theres no binding
Oh and also, will the bl motor runtime shorten if i add more cells for more voltage (7-8 cell pack)?
NY
but if your going to add up to 8 cells it will weigh it down and be a pain.
my setup is a mamba 25 w/ a 9200 kv c4 motor geared way down on a 6 cell 1600 mah battery. it goes about 35-40 mph
if you want even more power get a 3 cell lipo along with the bl system it would go 73mph.(then get air born)
What battery are you using, stock? I don't know why you are getting 8 minuets of run time.... I use a Duratrax IntelliPeak pulse charger and charge at 1 amp and I get around 15 minuets. Are you using full throttle all the time? I don't use full throttle a lot so that could be why I get more run time.
Then thats probably why you only have 8 minuets of run time. I don't have much room to drive the truck in the winter, so I can't go full throttle ,most of the time....
