mini t or micro t?
MI
mini t or micro t?
hey, i was wondering what i should get, the mini t or the micro t? i kind of like the micro t because its small enough to open up through my house but i like the mini t because i can run it outside without it flying away too. plus i like the mini t better because it is like $$20 more than the micro t and the micro t is kind of toy quality i think, please correct me if im wrong and tell me the reasons.
Thanks for all help
Thanks for all help
GA
RE: mini t or micro t?
Well it depends on where you are going to be running it. If you want to run inside the most, get the Micro T (Its definately not toy quality). But if your going to be running it outside more, get the Mini T. Hope this helps.
MI
ok thanks for the response. i would be running inside mostly in the winter and probably outside all the time in the summer. i guess it sounds like the mini t because i like the price for how much more you get and i like all the mods you can get to make it go really fast.
Banned
VT
the mirco-t is faster then the mini-t stock belive it or not. I was thinking about getting a mini-t or a mirco-t also but i went with the mini baja. its alot better.
Banned
VT
Its like $40-$50 more but you get like $80 more in up grades from the mini-t.
the esc and reciver are seperate so if you decied to go mamba u dont need another reciver also,bearings,2 sets of rear tires,upgraded motor,snthazid radio,battery,charger.,and 3 wire servo. so its worth it to me.
MI
alright i think im just going to get a mini t. ill wait till after christmas though because i might get one of the two for a present.
MI
ok but i just found this on ebay. i was just wondering if this would be any better before i make my final desission.
http://cgi.ebay.com/Team-Losi-Baja-M...em330062826523
GA
Yep it is better, it comes with a new esc and synthisized fm radio, bearings,2 sets of rear tires,upgraded motor,snthazid radio,battery,charger.,and 3 wire servo.
CA
ORIGINAL: Kokopelli06
GA
ORIGINAL: -Inverted-
LOL, nice copy and paste off golfcarter...
For outside, definately the mini-t or mini baja. For inside the micro-t, depending on space. My micro-t only gets run inside, cause I have enough space to do it. Where as my bigger trucks don't, cause they don't have enough space.
Banned
VT
the only bad thing is the mini-t is REALLY slow stock. less the 8MPH cuz thats how fast the micro t is and the micro t is faster. I would go with the mini baja. in fact i did lol.
ORIGINAL: rc18t145
MI
alright thanks, ill see what i get under the christmas tree and then ill see from there. maybe if i get a micro t for christmas and i really like it ill get the mini baja with my christmas money. i was just wondering why get the mini baja if im just going to trick it out in the long run anyways?
MI
ok thanks, does anyone have msn messenger? if you do that would be cool so its easier to talk about these things
