View Poll Results: A poll
Voters: 23. You may not vote on this poll
MLST VS Mini Quake se
MI
RE: MLST VS Mini Quake se
Both with be running a IB1400 pack.
GolfCarterForLife Keeps going on and on how The Mini Quake SE is 100% better than my Mini-LST.
I havnt ever had a Diff problem,I only stripped one servo because I got mad at it and over tightened it, I only broke one rim after going into a mail box at 30mph. Come one everyone Prove to Joe (Golfcarter) that the Mini-LST is better.
CA
Mini-Lst will be faster, AirPower was designed for planes where li-po's are used. Minilst wont draw as many amps, but the mini quake is lighter and has a smoother drivetrain.
id say it would be very close
CA
The mini baja is the exact same car as the mini-t, only differences are body, tires/wheels, and electronics. Since they share the exact same chassis and components I would consider them the same.
GA
I would get the mini lst. I have had one for a year now and the only problems i have had with it was a broken rim (That was a problem with the earlier models, they fixed that now), and the diff pinion gear stripping. Now dont get started on how bad the mini lst's diff are, i know they're bad but the Viscous diff come out late december, so a new mlst paired w/ the new diffs will make an awesome truck ready for anything[>:].
