1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Mamba Pinion Problem
Reply
Old 12-22-2006, 06:14 PM
Maniac05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Mamba Pinion Problem
I'm having a problem with my Mini T. The Mamba motor I have in it burns through plastic pinions like it's nothing. The shaft on the motor is not splined, so it reams out the hole in the pinion when I gun the throttle. I have a couple of metal pinions with set screws, but the are too small to fit over the shaft. Can anybody recommend a set of metal pinions that will fit?
Maniac05
Maniac05 is offline
Old 12-22-2006, 06:34 PM
andrewtexas123
andrewtexas123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mamba Pinion Problem
Look at towerhobbies the have a set of intergy pinons it is like a set of four and it fits perfect. They all have grub screws to!
andrewtexas123 is offline
Old 12-22-2006, 06:47 PM
Maniac05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you happen to know the shaft diameter of a mamba motor?
Also, if you mean this set, then they don't fit.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGWA8&P=7]Trinity Odd Number Pinion Set[/link]
Maniac05 is offline
Old 12-22-2006, 06:49 PM
andrewtexas123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yea thats what i mean, could you take a drill to it to make it fit?
Old 12-22-2006, 08:47 PM
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mamba has a 2mm shaft.
-Inverted- is offline
Old 12-23-2006, 11:22 PM
darindotson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mamba is 2.0 mm, and yes, the Trinity pinions fit. You may have to tap them a little with a rubber mallet, but they fit. Make sure to Dremel a flat spot on the motor shaft for the pinion grub screw to seat on.
darindotson is offline
Old 12-23-2006, 11:23 PM
andrewtexas123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What dreamel bit sould i use to do what you posted?
Old 12-23-2006, 11:32 PM
Mr. Mugen
Mr. Mugen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
robinson makes pinions for the 2.0mm shaft. If you try to drill it out, there is a good chance it will not be centered. I have done this and messed up several pinions. Just get the pinions that were made to fit it.
Mr. Mugen is offline
Old 12-24-2006, 06:11 AM
Gex_61
Gex_61's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Robinson Racing makes great pinions. I have them for my mini-t and all my 1/10 cars.
lol, pretty much all the cars I have.
I havn't needed to make a flat spot for the grub screw. I have a 13, 14, and 16 tooth for the mini-t and they all work great. No locktite or anything, put them straight on as they come.
Gex_61 is offline
Old 12-24-2006, 10:05 AM
TheArsonist21
TheArsonist21's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What tooth should I get for the LST? IM getting a mamba and I want to get tehr robinson razcing ones as well, so you think like a 15t on a 50t spur?
TheArsonist21 is offline
Old 12-24-2006, 12:48 PM
Gex_61
Gex_61's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't have a MLST. My mini-t had a 12 tooth on it with my brushed baja motor, but now that I have a mamba I run it with a 16 tooth all the time. So expect to gear it up a little.
Gex_61 is offline
Old 12-24-2006, 01:15 PM
Mr. Mugen
Mr. Mugen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would start with a 13 or 14 first. Which mamba are you getting? Oh yeah and start with the 54 spur. You are going to want to gear it down a lil first. Overgearing will kill your motor and esc.
Old 12-24-2006, 02:42 PM
TheArsonist21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, Then how about doing the 54T on the 15T gear? Its gonna be the 6800KV
Old 12-30-2006, 10:07 PM
xbox360
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mine does not go anywhere
xbox360 is offline
Old 12-31-2006, 12:54 AM
stu92
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have a comp x 13pion 55 spur and 3 cell lipo 1800
stu92 is offline
Old 01-04-2007, 12:17 AM
clockwork1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well duh. plastic pinions slip on. Get some golden horizons pinions .lol
clockwork1 is offline
