the official kyosho haf 8 electric and 09 mini inferno thread .
#76
My Feedback: (138)
RE: the official kyosho haf 8 electric and 09 mini inferno thread .
[8D]hi guy,s . i got the brushless mini inferno yesterday and grease the front rear center diff,s and hub,s . i have not ran it yet lol as i think it,s a litle to fast for the living room . i will post pic,s today of it . thank,s all and have a grate day .
#77
There is another motor out but its smaller at .06 its really cheap though if you can find one get the .09 from sirio.
The good thing about the sh engine is that it has a different manifold and good power delivery very linear.
Ant
Ant
#78
My Feedback: (81)
VA
ORIGINAL: AntWar
Ant
Ant
#79
A pick of the sh .07ci engine and a pick of another engine slightly bigger at .08ci the second engine will fit the nb with no mods at all.
Some links to ebay for the info and prices.
http://cgi.ebay.co.uk/SH-Engines-PT0...QQcmdZViewItem
http://cgi.ebay.co.uk/XRay-610001-0-...QQcmdZViewItem
#81
Will take some pics and get them posted over the weekend so you can see the throttle linkage and engine mods i used to fit the sh into my nb.
Ant
Ant
#82
CA
I have a Mini-Inferno and I am looking for the upgraded differentials. From what I understand the Inferno truggy has sealed diff's and they are a direct replacement for the ones in the inferno? Is this what I am looking for?
#83
Those are great diffs but the ones your refering to are fluid filled diffs like it's big brother the 1/8 inferno. You can get replacement diffs from kyosho for the KMI ST on their website or ebay.
#85
#86
CA
#89
My Feedback: (138)
[8D]hi guy,s . it has the rc18t esc and motor . it has a 1200 mah ib battery pack after market servo , gpm shock,s , futaba 2pl radio . thank,s
#90
My Feedback: (81)
VA
Looks good and strangley familiar, why did you take the Mamba brushless out of it. SHould have been alot faster than that rc18t motor.
#91
My Feedback: (138)
[8D]hi budie . yes it would have been alot faster lol . but i have to upgrade the diff,s before i put the brushless back in it . have not ran it yet though lol .
#92
The sh engine comes with two mount types one of standard flange type and a kyosho base style mount to fit the nb standard mount i had to grind the base mounts enoung so it can seat correctly as can be seen in the pics i have no bearing leaks or sealing problems with this motor and have put it through some abuse including jumping it 27 feet on one of those potable plasic bmx ramps bent the alloy shock towers a little just bent them back by hand and all was well only bent them on the few runs where i run off the ramp.
Ant
Ant
#93
My Feedback: (81)
VA
Thanks AntWar,
I am thinking that if the Drake .095 is a better fit than that then it will be worth the extra bucks, for me that is.
#94
Just ahd a look at the trinity site and it appears the drake motor is and rebadged sh from the pics on the home page at the top.
http://www.teamtrinity.com/shop/engines/drake095.html
#95
My Feedback: (81)
VA
Yes I agree, but the bottom must be different, because its supposed to be a drop in upgrade for one of these buggies. The quetsion is which one? I hope its the Vulcan, because my ACME NB16 has the same motor and pipe set up, meaning it should fit my buggy, but I will ask someone who sells it to make sure. When it comes to nitro motors, I really don't like modding the mount.
#96
Only if you buy the mount and manifold they could both be used on the sh as the case was the same before i ground mine to fit the standard engine mount.
Still the price is ok and if it performs like the sh its still a good buy i would go for the standard one though as you will get enough part failures unless you have metal diffs in.
#100
My Feedback: (81)
VA
ORIGINAL: AntWar
