Official Pro-Pulse Thread
MI
RE: Official Pro-Pulse Thread
HOLLY COW! Ten bucks! Might try to fabricate something. Thank you for the post though!
I broke this off pretty quickly. Has anyone else had this problem?
TX
ORIGINAL: aviator24
Yes! Ten bucks! Yes, mine broke off the third time I ran it. I found a small rubber pipe and cut it to fit and put the screws on the inside of the pipe. So now the screws don't get hit head on.
so do any 18t wheels and tires fir on the pro pules
does any one have a list of all the parts from an 18t that fit directly on with no mods needed
i also dont use the RS packs, i use a 6 cell 7.2v IB1400 pack which i charge using me Parahan, the truck flys,
#31
IN
the list that i have on the first page, only the hop ups i have done are the ones i know to fit. a-arms also are exactly the same.
#32
ORIGINAL: Haulin Azz
What can -not- be interchanged directly are the motor mounts, bumpers and shock towers.
The shock towers should be easily adaptable with an aluminum plate of proper dimensions and with holes drilled in the proper locations. Three holes in the center of the plate to bolt to the pro pulse chassis, two on either outside edge of the plate to bolt to the RC18 shock tower and allow the ball joint to thread for the turnbuckles to attach. Although this is a crude hack (definitely going to alter the suspension geometry a bit), it should still be stronger than the plastic tower if a thick enough plate is used, but it may result in needing longer machine screws to make it work. Anyone with a dremel tool and a steady hand could make this. Definitely a hack, but a workaround nonetheless.
So the only mystery part left is if the RC18 drive shaft is the proper length and the spur gear attachment point at the right spot on shaft? Obviously the spur gear would need replaced along with the driveshaft as the RC18 uses a hex and Pro-Pulse uses a center pin akin to the Itsy Bitsy Spider as already pointed out. So, does anyone have the parts around to do some measuring?
But I do have to concur, I think this thread is unneeded, so I will also post this in the other thread to keep it all in one spot.
#36
HI
ESC problems. This is the third pro pulse i got (exchanged twice).
First one was a bad shock.
Second was a TX problem
and now the ESC doesn't seem to be working.
I turn on the PP and the Transmitter and the steering servo kicks on but the ESC red LED doesn't go on. Is it fried? I can't return this one b/c i switched the connectors on the Stock ESC to dean plugs.
I am totally new at this so i am looking for someone to point me in the right direction for next steps.
If i need another ESC which one should i get? I want to also run BL since i'll prolly need a new ESC.
Only problem is I never programmed an ESC and would like the car to have braking and reverse. The problem is i don't have any high end TX to program the ESC which i read I might need. Do you think my LHS could help switch it out and program the ESC?
#38
ORIGINAL: pimptempura
#39
IN
the bl esc i have was sorta hard to understand, you can program it with the stock radio. i will hopefully have most my upgrades done tomarrow so i will post some pictures of my racing pro-pulse.
#40
Yay, i got a video up: [link=http://www.youtube.com/watch?v=L-A0kmmFTRQ]click for video[/link]
NOTE: i was focused on getting the buggy on film, not my best driving.
#42
IN
i am wanting to make mine into a truggy/ prerunner type truck. then if we move to alabama or florida (hope we do) i will put paddle tires on and have a sweet dune basher! ne way that is a way off though. i want to make this thing crazy though!! i will get some pics today when i finish working on it.
#43
IN
birel19 you should get one! By the way guys, i have made custom bumpers for mine front and rear and the work great!! i put coats of shoe-goo on the front one to make it really strong lol!!![&:] I will be racing again this saturday so that will be cool! Now that i have just about every single bug worked out it is handling great and is an awesome racer!
#44
haulin why you tryin to steal my idea? j/k i orderd paddles for the front and back last week and im just waitin for them to come in. i live at jacksoville beach in florida. i bought a vw baja body and paintied it this weekend. ill put up a pic as soon as i get the tires in and put them on. paddles are cheap on ebay like a set of 2 wit rims for 7 or 8 before shipping.
#45
IN
lol! i wish we lived down there.[] My tie-rods just came in so most my hop-ups are finished, pics will be taken soon!
#48
man i finally got my paddle tires, but im kinda disapointed i could have swarn that when i ordered them that they came with rims but they dont so now i gotta stop my hobbyworld on the way home and pic up some rims. ill prob just get the cheap white dish ones and paint them or something. cant wait to put it all together and post some pics
#50
well i got it all done. i took it to the beach last night and it was bad azz. i took some pics but didnt have time to upload them. ill do it tonight.i cant wait to get either the twin motors or brushless. im really skeptical. i dont want it to go so fast that i cant keep up with it, but then again i like the look of the twinn motors. but i also want to be able to haul azz and whip the competition if the challenge ever arises. so i dunno i may just be patient and see if anyone sells the setup that you have on ebay, then ill pick it up. or maybe i can get my girlfriend to get it for me haha.
