6800 mamba Mlst Help Needed
OH
Since reading of people over/under gearing their brushless setups causing the motor to burn up, I was wondering if the stock gearing is ok for the Mamba running a Dynamite Lipo setup? If not then what gearing setup would help rid of this? One more question is since I purchased the USB adapter cable can I program the ESC so that I can run stock gearing? LOL and Finally how many volts should I set my voltage cutoff at for a 2 cell Lipo?
RE: 6800 mamba Mlst Help Needed
yes you can, I have run mine with that same set-uo and works great on stock gearing, and like eyekandy said, put the cut-off at 6v
I actually run with a mamba 4200kv but I also have tried with the 6800kv of my rc1t8t, with the 4200 is like 3 mph faster that stock and with the 6800 probably 5-10mph faster than stock on a 2-cell
