1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Easy micro-t e-clip fix
Reply
Old 01-16-2007, 05:46 PM
Seek and Destroy
Seek and Destroy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Easy micro-t e-clip fix
** This was not my idea, I am pretty sure that eyekandyboats said something about it somewhere on here**
First off, you need to rip off the e-clip. I did this with pliers. The first one wouldn't move until I twisted the thing up with a screwdriver. 2nd one came off perfectly. ONce you do that, take off the wheels. Do you see the little circle thing in the center of the tire that pops out? Well you need to shave that off. I did this with a dremel
This camera isn't that good, but that dremel was moving at 7500rpm when I took that photo.[&:]
Once you do that, the center ridge thing should be completely gone, like this:
If it does, then put it back on the axle, and pesh the body clip on (I used stock ones, but I don't have anymore to do the front, I can't even attach the body now[&o] ) and it should look like this:
The reason why you need to shave off the center ridge thing is because other wise it binds, but will still move.
THese also work great because if there is hair on the axle or something, you can just remove the clip instead of trying to remove those evil e-clips. It does look kinda dumb though.
Seek and Destroy is offline
Old 01-16-2007, 05:49 PM
Seek and Destroy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Easy micro-t e-clip fix
And for anybody that wants to know what the front wheel looks like, it looks like this.
Old 01-16-2007, 05:51 PM
hands without shadows
hands without shadows's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It might just be me but none of your pictures work.
hands without shadows is offline
Old 01-16-2007, 05:52 PM
Seek and Destroy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They worked fine for me.[&:] Give it a minute to load, they are 600x 800.
Old 01-16-2007, 06:12 PM
ChrisJuliano
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes they work
ChrisJuliano is offline
Old 01-16-2007, 06:56 PM
poe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How did you get the e-clips off without breaking them?
poe is offline
Old 01-16-2007, 07:01 PM
Seek and Destroy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Grab the m with needle nose pliers. And then just start ripping. You can also try getting under then with a small flathead and that'll lift it up and loosen it, and sometimes even pop it off.
Old 01-16-2007, 07:04 PM
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
E-clips drive me crazy. I personally would like to see some threaded axles and a lock nut.
-Inverted- is offline
Old 01-16-2007, 07:08 PM
Seek and Destroy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: -Inverted-
I was going to do that, but I didn't have a nut small enough.
Old 01-16-2007, 07:10 PM
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do they have threaded axles, I've never seen one in person so Im not sure?
Old 01-16-2007, 07:13 PM
Seek and Destroy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nope, it just a straight smooth peice a metal, with a notch in it for the e-clip.
Old 01-16-2007, 08:50 PM
..............................'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i did mine like these a little wile after i got it, you dont even need to grind the wheel any...
.............................. is offline
Old 01-16-2007, 10:10 PM
Seek and Destroy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did on mine, because it was really slowing it down and binding.
Old 02-01-2007, 07:06 AM
Vossler002
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use a razor blade a stick it in the small crack opposite the opening and pry so when they do come off there not gone
Vossler002 is offline
Old 02-01-2007, 01:35 PM
rcworld2000com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
they do have threaded shast on ebay heres a link to the fronts he sells both front and rear mine are on there way
http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true[link]http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170076914985&fromMakeTrack=true[/link]
rcworld2000com is offline
Old 02-01-2007, 02:14 PM
raptornut
My Feedback: (20)
raptornut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a thought but you can buy a 4 piece e-clip tool for $10.00
raptornut is offline
Old 02-01-2007, 02:28 PM
Mr. Mugen
Mr. Mugen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I find it kind of comical that so many people have problems with these little e clips. It is quite simple. I am assuming your all have at least one hand with five fingers..........right? So if you do then you must be able to move your fingers.....right? OK for those of you that did qualify and are still with me, here is a simple trick. Use your fingernail! LOL Is there a reason you must use an object to remove them? Heck no. Unless your one of those prettty nail guys (prefectly manicured.....everyday) you should be able to easily pop them off with your fingernail. If not use your dremel and put a notch in your nail.....LOL! Just kidding! Your thumb will be right there of smoosh against the rim and axle so is sandwiches the clip and it won't fly anywhere. I put them on with my mail too. They are very small and flexible. Forcing them with other metal abjects is not the answer.
Mr. Mugen is offline
Old 02-02-2007, 11:05 AM
MrN8
MrN8's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use my fingernails and it works fine, but I still pop a clip off into never-land every once in a while. I just realized last night that I have some UV paint in a spray can so I sprayed all my e-clips and screws with it and if I lose one, I can just turn on a blacklight and they magically appear. [8D] I'll see if I can get a pic of how well it works over the weekend.
MrN8 is offline
Old 02-02-2007, 11:30 AM
Al P
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: raptornut
Where did you get that set ?
I have been using jeweller's screw drivers carefully. No problems (so far).
Al P is offline
Old 02-02-2007, 08:59 PM
raptornut
My Feedback: (20)
raptornut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From wwwthetoolwharehouse.net They are in New Jersey, or do a google search for e clip pliers and you can probably find some in canada.
Old 02-02-2007, 09:06 PM
jeep2003
jeep2003's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i never have any problem with e clips. i just use an exacto knife to get under them and use my thumb to keep them from flying away. Then when reinstalling them just position it and snap it on
jeep2003 is offline
Old 02-22-2007, 05:58 PM
HTMracing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used a Utility Knife and they came off fine
ORIGINAL: poe
HTMracing is offline
Old 02-23-2007, 01:33 AM
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go to www.thetoyz.com they have the threaded wheel shafts.
t9dragon is offline
Contact Us Archive Advertising Cookie Policy
