newb question about mamba in mlst?
CA
ok i have searched and found mostly what i needed to know, but i have a question, i want to make sure i am geting the right stuff the first time. so besides the drive train will this go right into my mini lst http://www.b-p-p.com/proddetail.php?...mamba6800combo ? if so what els if anything will i have to change(besides the weak drivetrain)? will the stock radio and everything els work? would this be a good combo? and also what kind of performance can i expect with this. sorry for the newb question that has been asked before. i just want to make sure thanks guys
RE: newb question about mamba in mlst?
hey welcome to the forums, yeah that drop in rigth into the mini lst, and is a great up-grade and works well with the stock radio, what battery do you plan to use?
CA
not sure yet what battery, maby a 2 or 3 cell lipo, that is what will give me the most performance and run time with lighter weight right?
CA
i finally get decided on a motor that i want to run, and then i hear people saying dont get the mamba blah blah blah, this is good performance for the price right? it seems that a wraith with a quark 33 is the best setup, but i dont want to get a new radio that u need with the quark. so i guess i am going to just buy this setup and not listen to the people that say not to get the mamba[sm=confused.gif] now i have to get to the difs and junk. what diffs and center diff and stuff would work best with the mamba? stock gearing is prety good with this setup right?
yeah I run my mamba with stock set-up and worked perfectly until a added a center spool...oh well, ill get the metal diffs.
CA
will my mini lst haul arse with this setup? wheres the best place to get lipos? and what charger do i need?
