OFFICIAL VENDETTA THREAD!!!!!!!!!
#251
CA
RE: OFFICIAL VENDETTA THREAD!!!!!!!!!
the same way everyone else does.. order it online from japan.. http://www.pro-s-futaba.co.jp/ send them an email requesting info on the yokomo truggy
#254
ORIGINAL: budha24
Thanx for the info I was already planning on the CVD's. Does the ESC and motor overheat easily? As far as the ESC goes I probably would upgrade to the Spy Micro eventually.
#256
jaejw1 , do you know any info about the vr3 motor? like is it the same turn as the rtr motor... or what makes it faster than the stock motor. is the can a 380 size or 400 size? can i call the vr3 a stock motor cause duratrax makes it? would the vr3 be allowed in stock 1/18 classes? anyones comments about this are welcome
#257
CA
dont know if it is allowed.. but if not.. then use the stock motor,, and advance the timing on it... that is if they allow you to do that
btw a 380 and 400 are the same
#258
My Feedback: (138)
[8D] i put some little up-grade's on my vendetta today . i put on the shock bushing's and alum. battery pack post and stering rod's . thank's all .
#260
i have a question: can the stock dogbones and cv shafts take the abuse of a brushless motor. and if not what should i upgrade first the front or back. Or should I just upgrade all the cv shafts and dogbones to aluminum then buy the motor then i could buy an aluminum spur gear too (oh and the motor is a mamba)
i will have 330$ so will i have enough for the vendetta -160$ the better battery 40$ that leaves 130$ for the motor and the aluminum upgrades .
Also do i have to buy a different speed control for the mamba or will the stock one work with the brushless motor
thanks
thanks
#261
CA
get all steel cvd's.. and alloy outdrives.. but you will need to upgrade to ball diffs in the future... and whih mamba motor you plan on using.. cause the lil tiny motor will have a hard time trying to push the heavy vendetta..
get the esc,, and buy a golden horizon gh4700 motor and gear it 19t pinion and 45t spur... and dont worry about an alloy spur.. just stick with the plastics..
#264
ORIGINAL: evader_st.18
thanks
thanks
Place at least a $125 order and for a limited time we'll take $20.00 off the total. All you have to do to claim your savings is click on ad number 011C3 and it will be placed in your shopping cart. This special offer is not retroactive. Please, only one promotional ad number per order.Best price Ifound on atomic steel cvds is rcraceday.com $13.Also the knuckles are a fair price to.Bishop power products will give the best price on a gh4700 /w mamba25 combo.They also have free shipping
#267
ORIGINAL: eamedia
thats a cool mod, but the aluminum knuckles work very nice, and they are not much heavyer than stock
#268
very true, all the duratrax upgrades are expensive... aluminum knuckles, tierods turnbucles, steel cvds, ball diffs, together cost almoast as much as the rtr car
has anyone upgraded the bearings? im gonna upgrade them when i rebuild my vendetta with the graphite chassis
#271
IL
ORIGINAL: jaejw1
btw the motor limit on the spy micro is 280 can.. you need a 400 can just to push the detta
Also I saw a brushless cobalt motor at tower and it said only requirement was a 25+amp ESC. Can you use the molded ESC that are used in planes like this one? [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGTZ2&P=7[/link]
If so what else needs to be changed? Thanx for the info.
#272
CA
all because no one listens to me,,,,,,,,, if you dont like the price then send mass emails to other companies asking,, beging,,pleading with,,demanding that they make hop ups,,,, yeah and atomics arethe only 2 besides duratrax or anderson that makes hop ups,,,, supply and demand ,,, there are no competitors for duratrax,,,,,,
also I dont care too much on how they do things.... why would I buy steel cvd's if part of the price is for the steel outdrives I will never use,,,,,,
guys stop complaining and start typing,,,,,, I personally have sent about 20 emails ,,,, it is now time for you guys to do the same
#273
ORIGINAL: jaejw1
I wasn't complaining. I was just wanting to know what you thought about the mod that someone did to the stock knuckles.
#274
the only other company id buy would be MIP.. and they are quite expensive as well.... basically if you want a bulletproof vendetta, you have to pay top $$$ if you want to replace broken parts get the plastic knuckles for $4
to make any car a reliable racer or basher you gotta pour the $$ into it
#275
CA
no I wasnt complning at any one person,,,,, im conplaining about duratrax..... I really would like to support them ,,, I even sent them an email about sellong the steel outdrives seperate from the cvd's,,,,, this makes too much sense
no I havent done that mod but im sure it holds,,,, I have alloy knuckles,,,, I bought all my hop ups before I bought the car
I would love for MIP to make cvd's
I think duratrax needs an R&D team or a race team
someone that could give them advice and they listen
also I switched to 19/41 with the permax motor...... I couldn't drive it..... now the motor gets warm,,,, hot to touch after 5 seconds just too fast
