OFFICIAL VENDETTA THREAD!!!!!!!!!
#77
CA
RE: OFFICIAL VENDETTA THREAD!!!!!!!!!
it is a bigger tire.. and the treads are made for racing... i prefer to use the proline crime fighters.. with the proline wheels.. which are made to withstand the totures of racing http://www.rcmart.com/catalog/produc...ducts_id=21720
#79
CO
Aren't ther more motors that have the power to run the vendetta besides the VR3? such as that baja motor for the Mini-t and that Reedy mini max modified motor?
#80
CA
you want a 400 can size motor.. anything smaller will get very very very hot.. the detta is too heavy and the gearing isnt motor friendly..
just go brushless..
just go brushless..
#81
CA
i finally stopped the rear hub hinge pin from moving
with both my buggy and truggy i had a problem with the rear hub pins working htheir way out to the wheels causing the wheels to not turn as freely..
i took the pins out placed them in a dremel.. and turned the dremel on high.. i then used that metal cuting disc and made a groove on each end of the pin. and then i placed an e-clip on there.. and .... no more movement
one less thing i have to worry about while racing
http://www2.towerhobbies.com/cgi-bin...7&I=LXJAG6&P=K
#84
SC
ORIGINAL: jaejw1
Permax should be here Monday! Can't wait!
D.
#86
SC
GH 4700, 2S Lipo (Thunder Power 1320 mAh), Quark 33a Pro Car, 19/45 gearing, 70 wt. front, 90 wt. rear, Duratrax Steel CVD's front, Atomic Steel CVD's rear, Atomic ball diffs front and rear, aluminum front knuckles, shocks, and standoffs. Spektrum 2.0 radio and receiver.
#88
CA
ORIGINAL: darindotson
are you running on dirt or carpet.... what tires?
#89
SC
Well, I think I made a boo boo. I ordered the 2.3 mm shaft, since I have all these aluminum pinions laying around. But I have noticed absolutely no wear whatsoever on the aluminum pinions after running the GH 4700 around for about 3 months. I'm sure the Permax will shred it if it's as powerful as you say. Then again, I'm a gear mesh nut, so I always make sure they are meshed properly and lubed.
I'm running Yeah racing Mini Inferno wheels with Proline Crimefighters- they hook up really well. Had a great day at the track- raced 3 stock Vendettas, as well as 3 other Mini-T's. Brought home the wood, but then again, I was racing a bunch of kids. Of course, some of those kids were mine, and are good drivers!!
Thanks for all your help! The Permax should be here tomorrow- I'll let you know how it goes!!!
D.
D.
#91
SC
ORIGINAL: junebug48
[8D]hi budie's . darindotson you need to post some pic's wen you put it all together lol sound's like a nice buggy . thank's guy's .
Darin
#92
CA
how do you like that lag thrust the quark gives... lik someone pushes a button AT THE RIGHT TIME..lol..lol.. i love it
also if you are looking for a lil extra traction.. spray the crime fighters with wd40 and let them sit for about 10-15 minutes..
#93
My Feedback: (138)
[8D]hi budie's . darindotson it look's very nice . i was wondering how many of you's race your vendetta's off road ? just wondering . thank's guy's .
#94
CA
i do ofcourse..lol.. and enjoy every minute of it.. winning or loosing.
http://www.rcuvideos.com/view_video....08a8e098112185
http://video.google.com/videoplay?do...08690931469823
#97
NJ
that was a longgg race.. (first vid) Hats off to you Jae. You are a master with your Vendetta for sure..
ORIGINAL: jaejw1
#99
CA
ORIGINAL: FlyinGN
ORIGINAL: jaejw1
#100
my detta setup... vr3 untimed, mini quake heat sink, atomic fan, hitec hs-56 micro servo, spektrum micro reciever, novak micro esc, front and rear ball diffs and cvds, front aluminum knuckles, stock wheelbase, stock tires or the mb4 hards depending on track conditions, and 1400 matched cells
