Mamba & 9200kv.....WOW!!!!!
Slammed this 9200kv into my 18t Factory team with my mamba, insane freaking insane! This is the fastest little thing I have ever witnessed. It smokes my factory GT2, XXX s with 10 turn,TC4 12 turn. I cannot believe how fast this is+ I got over 6 minutes run time!!!! Anybody else have this eye popping experience??I seriously would put this against a Jato 3.3 or 4 tec any day on a drag strip![sm=drowning.gif][sm=thumbs_up.gif]
RE: Mamba & 9200kv.....WOW!!!!!
3 cell lipo 11.2 /2100/7.4 Thunder Power. Before I drove it on the road I dropped it down ( HERD TO MANY STORIES OF SPEED STABILITY) I tested it in my hand and was giving it full throttle, the tire flew of the wheel. I had spot glued it in 4 places because I wanted to be able to take the tires off easily. The rpm through the tire further than I could have.
Yeah the run time will be longer. I confirmed 6 but it was longer. I stopped because it was getting very hot. Even with my spektrum range I know there is still some throttle I havent seen. Question? Everthing is aluminum except the main chassis. Should I put the aluminium chassis on or will it weigh this already light car down?
If every thing els is already aluminum why not have an aluminum chasiss... It will weigh it down some but I don't think you are going to be having any problems with speed anytime soon lol.
I know what ur talking about! I have C4 9200kv system with quark pro33a esc it is insane! even more when u run 5s lipo yes 5 cell lipo![X(][X(][X(] Just Don't Wreckit trust me at those speeds when u werck it hurts in the pocket baaaaaaaaaaaaaad![:@]
I guess I'm trying to talk myself out of putting more into this car. After the chassis I could have had an HPI Hellfire or XrayT2007 instead of one of the fastest 18'T'S. However after todays run I'm happy with my little jet!
CA
oh shoot you must be tom phalen,,,,,, sir how you doin,,, read your piece on javomg your rc18 with mamba 6800kv go close to 80 ,,,, glad to see you wete able to do it,,,,,
few questions how long did it take you to reach that speed,, distance ,,,
what kind of body
what kind of tires
did you use any lead weight
what gearing pinion/spur
what kind of body
what kind of tires
Well right now stock tires, With all the meatel it helps but i used a stiff shock springs to help. 17t pinnion and 60t spur,Speed http://www.killerhobbies.com/items/t...012-detail.htm
Bashing
http://www.killerhobbies.com/items/t...98P-detail.htm
Racing
http://www.killerhobbies.com/items/t...092-detail.htm
I have about 1500 Feet of very very low traffic road on my street, maybe one or 2 cars a day.
Bashing
Racing
ORIGINAL: jaejw1
what are you using to calculate speed
ORIGINAL: gettnbetter
The nurse at the hospital that diagnosed the size of the bump on his shin when the car grazed it! ahahah!!!
ORIGINAL: jaejw1
