fixing rims?
fixing rims?
Is there a way to fix a broken rim? I mean like totally broken where theres a circle in the middle and the nut and some plastic still on the axle?
If you cant do that then can you take the tire off the rim and just buy some new rims?
ON, CANADA
RE: fixing rims?
You cant fix a broken rim..........if you are that cheap you need a new hobby. You can remove the rim by dissolving the superglue with acetone or chucking your rims in boiling water for a few minutes to weaken the glue.
