Mini lst motors & other questions
What are good motors to run in a stock mini lst. I would like a lot of torque but also good top speed.
Are the diff upgrades needed?
Also how do you fit a mini t style 7 cell battery in the mini lst>?
GA
RE: Mini lst motors & other questions
ORIGINAL: t9dragon
I would have to disagree with you on your comment. My Mini-LST with a Mamba 8000kv and a 7cell pack is faster then a stock Mini-LST.
GA
ORIGINAL: t9dragon
WOW, that is what he said isn't it. My eyes must be going out.............................
CA
My bad guys!
I meant cost wise brushless will only be slightly more. A good pair of brushed is going to run about $80. An extra $20 will get you more power and efficiency.
ORIGINAL: -Inverted-
Well I was going to run the Krystals which were $80 for two.
wow that is pretty expensive, what do they have special?
CA
Hand modified.
Yes, dual brushless is possible, just not that practical. Speed is not much higher then with a single motor, just more torque.
