1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Biggest 3 cell lipo to fit rc18t
Reply
Old 03-20-2007, 09:35 AM
damaged123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Biggest 3 cell lipo to fit rc18t
I was wondering what is the biggest 3 cell lipo that will fit the rc18t- or a 7 or 8 cell people know a good layout with and have high mah and discharge rate.
damaged123 is offline
Old 03-20-2007, 12:09 PM
Hacker Da-Cracker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Biggest 3 cell lipo to fit rc18t
whats you mean the bigest 3 cell lipo? you mean one with the highest MAH?
Hacker Da-Cracker is offline
Old 03-21-2007, 06:31 PM
damaged123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah, or what someone reccomends to use for a 3 cell lipo., i just want to know which ones are good that will fit rc18t
Old 03-21-2007, 06:35 PM
damaged123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just want to upgrade from my 6 cell stock battery, but i have cogging issues, only from a dead stop though. I still though would like something a tad bit faster so any reccomendations? I have a Mamba 25 with C4 8000 kv brushless , stock 14t pinion stock 60t spur, basically everything but suspension parts are stock.
Old 03-21-2007, 07:44 PM
damaged123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
any suggestions for batteries?
Old 03-21-2007, 10:45 PM
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you updated your Mamba ESC? If not then that may be why you are having cogging issues.
t9dragon is offline
Old 03-22-2007, 08:40 AM
damaged123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no i have not, i dont have the link yet. You think updating it will even take care of cogging on such a crappy battery?
Old 03-22-2007, 09:06 AM
Needrcspeed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are running a stock 6 cell pack, that will likely cause cogging. If you want a good ni-mh pack to use with the Mamba, check the IB1400's or the elite 1500's from cheapbatterypacks.com. One other alternative would be to gear the car down. If you are using the 55T spur, try switching to the 60T. If you are already using the 60T, try a smaller pinion gear.
If you decide to make the switch to li-poly, you will really benefit from the purchase of the USB link for the Mamba. I have used the Thunder Power 1320 mah 3 cell packs in my RC18's and had good luck with them.
Needrcspeed is offline
Old 03-22-2007, 09:47 AM
spicedcrab
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i also have had great luck with the thunder power 1320, and its very light to help keep the truck weight down, this will also make your truck accelerate faster. needrcspeed is right also about gearing if its too high that will make cogging worse, i had to lower my ratio. if you want the most mah that you can fit the thunder power 2100 works (but very tight length wise), the common sense 2000 is a cheaper option at about $39 and it still handles 20amps cont. that is plenty for your motor (my mamba motor pulls about 10 or 11amps when im pushing it hard) also one more common sense lipo that works is the 1650 for about $34
i have used all of these in my truck and i got them from www.superfastrc.com (because they had the best delivered price) i have my personal oppinions on each one here;
TP1320 - my favorite for racing in the dirt because it makes the truck light.
CS1650 - great all around basher mixing lighter weight with long run times.
CS2000 - my favorite one for bashing and high speed parking lot fun, very long run times
TP2100 - name brand top notch quality and c-rating (although i havent seen a difference playing and bashing from the cs2000) costs more
spicedcrab is offline
Old 03-22-2007, 09:49 AM
Needrcspeed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: spicedcrab
Good information!
Old 03-22-2007, 11:39 AM
mikemcnair
mikemcnair's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Needrcspeed,
thank you for all of the help!! it appears i am in the same boat as the original poster in this thread.
mikemcnair is offline
Reply
Display Modes
