Mini T Pinion Screw Question
IL
My Mini T came with a metal pinion in the toolbox. I used the smallest allen I have and I still couldn't get the little screw out. Does anyone know off hand the size so I can get one tonight? The Mamba 8000 and 3 cell lipo make the plastic gear with no lock screw fly off right away.
NC
RE: Mini T Pinion Screw Question
If i'm not mistaken I believe its a .5mm allen. I tried all my allens with no luck but one that came with my Traxxas revo fits perfect. and my LHS dealer said ihe thinks it is .5mm
NC
I see ya got a revo 3.3 listed in your garage. Check through the tool bag that came with the truck you probably have one in there it's the tiny baby allen wrench..
CA
make a flat spot on the motor shaft i dont have a mamba but it might help , the guy at the lhs did that with my orion baja motor
NC
i've never had a problem with mine slipping. It would throw the stock plastic pinion right off the shaft. I just tightened the hell outta my titanium and keep checking it. Lock tite helps also. or even a dab of some ZAP glue.
