Need help on purchase of vendetta st
I have finally read and read and seems like the vendetta st is the winner! Will I have been trying to pick out a battery because I heard the stock one is crapy. How about this one from cheapbatteypacks.com
6C/ELITE1500A/Double Stick/22AWG Wire--With FDEAN
I also have a couple of these servos for the steering laying around the house would this be a good choice? http://www.hobbyhorse.com/hitec_hs635hb.shtml
Could you guys recomend anything else to me that I should get? Do you guys have rechargable batters in your tx? or do standard AA's last long enough? Thanks for all the help!
RE: Need help on purchase of vendetta st
Lots of people use and like that pack, myself included. I would go with 18awg or larger though.
If your using the stock ESC, you will have to solder on a male deans.
Where can you gt Deans plugs, i just had to cut off the stock esc/motor conection becouse it destroyed its self after runing a 1200mah pack and the 650mah pack back to back last night!
