Charger question.
Charger question.
I have a pro peak varipulse 2500vp. I just used my third set of batterys in my micro-t charger and dont want to buy more. I was wondering if i could just use the plug off the losi charger and charge the 150mah battery with the varipulse charger. My friend has the same car but a different charger and charges it at .5 amps. Will that work without harming my battery?
Thanx in advance, Aaron
RE: Charger question.
I dont have the money to keep replacing the batterys and recargeables are just ehh idont know what ill do. The kid i bought it from charged it at .5 amps. So i dont think it'll hurt it.
Ok Well it has benn charged probably 50 times at .5 amps and is about 3-months old. I think i am probably just going to sharge it at .5 amps and see how long it takes to charge then how long it lasts. Thanx for your help.
Ok i detemined that the 150mah battery takes 17 minits to charge and almost 7 minuets to discharge. Thats full throttle runs jumping in my hallway. Is the charge time and discarge time good or bad or ok? All help appriciated.
