Mini Quake gear diff problems
CA
i just got these gear diffs for my mini quake and the out drives don't work with the cvds. is there certain out drives i have to buy for it to work? thanks.
btw, this is a bone stock mini quake se.
RE: Mini Quake gear diff problems
from what i saw in the manual this is what you need http://www2.towerhobbies.com/cgi-bin...?&I=LXJAD9&P=7
Ok so you say you have mini quake se
which means it whould come with Alum CVDs and Alum Ball Diffs
there fore the link above will do you know good, being that is ment for the MQ RTR that uses plastic telescoping drive shafts
you should have the blue alum CVD the gear diffs are ment for the RTR and USE the plastic outdrives shown in the link above
the [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKPB7&P=M]Alum Ball difs [/link]come with the correct the Out drives as well as the [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJKV3&P=Z]cvds[/link] them self , im not sure if u can just get the alum out drives alone. and i think the Alum ball difs alum out drives are part of the ball dif and can not be used on the gear diffs
so i think you will need to buy 2 sets of CVDs on order to get the 4 spare outdrives, which then can then be used in the gear diffs.
but the real question is why do u want to use gear diffs over the ball diffs.
