Mamba Question
BC, CANADA
Mamba Question
I just put a Mamba Comp X brushless system in an RC18/T. When I give it full throttle, as it accelerates, it's like the throttle curve is sort of stepped. It accelerates and then it sounds like the motor cuts out for a split second, and then it starts to accelerate again. It seems to do this a couple of times until it reaches top speed. Is this normal?
Also, anyone know what the safe max operating temperature is for these motors.
BC, CANADA
RE: Mamba Question
Hmmmm, now the power has stopped cutting out. At first I thought maybe the motor was drawing too much power for the battery and the esc was going into power saving mode, but then the car started running properly even with a half drained battery. It's running really quick now. Weird.
