Kyosho Mini-Z goes 2.4ghz
New Perfex Transmitter, KT-18 ASF
•The new KT-18 TX unit will allow 40 Mini-Zs to race at the same time.
•Will automatically search for an open Frequency, NO Xtals needed!
•Radio response speed increased 33%, compared to the KT-5
•Only one radio required to control other 2.4ghz equipped Mini-Zs
•Steering angle and throttle angles can be adjusted
•Digital trim adjustments
•Blue LED lights indicate Power, Bind Mode, and Training mode
•Only 4 AAA Batteries required for TX operation
•Expansion slot for add on features. (available in future)
February 2008 Arrival
80021B TX only
MSRP NYA
Release Date: Jan/Feb
MR02LM Series with 2.4Ghz System ARR
•Fully factory assembled chassis with high capacity FET
•NEW 2.4Ghz radio system
•Pre painted bodies
•Four sizes of pinion gears
•Pinion gear tool
•Spacers for front suspension adjustment
TECHNICAL DATA
Scale: 1/27.6
Length: 180mm
Width: 78mm
Height: 39mm
Wheelbase: 102mm
Weight: 130g
Gear Ratios: 7.3, 6.3, 5.5, 4.9:1
Tire Diameter: (F)23.5mm (R)27mm
Tire Width: (F)9mm (R)12mm
Transmitter: KT-18 (Sold Separately)
* NEW FEATURES *
•New motor case and friction dampener as
standard equipment.
•Motor now located 5.5mm lower and
2.5mm toward the center, compared to the MM motor case.
•Equipped with I.C.S Port
•Transmitter and receiver response time has increased 33%
•2.4Ghz Technology
30441KR-B Porsche 962 No.10
MSRP NYA
80021B TX only
MSRP NYA
•Pre painted bodies
•Pinion gear tool
TECHNICAL DATA
Scale: 1/27.6
Length: 180mm
Width: 78mm
Height: 39mm
Wheelbase: 102mm
Weight: 130g
* NEW FEATURES *
standard equipment.
•2.4Ghz Technology
MSRP NYA
RE: Kyosho Mini-Z goes 2.4ghz
Whomever gets one of these setups, please post how many other cars you can program off the one radio.
I'd assume all future Mini-Z chassis' will soon have this radio system built in.
It would be nice to only have one radio and 40 cars programmed on one radio.
•The single ugliest tx in existane...
how fast can they go?(stock imean) that tx's specs are pretty nice, but it is the single ugliest thing i have every seen! how much do they cost?
are they comparable to a micro t?
imo
mini-z's crush micro-t's
in every category except jumping
well duh the mini-z is onroad lol
my mini-z stock with bearings and rechargeable batterys
goes about 12-14mph and the best thing is i can charge for 15minutes
and run for an hour hehe
and with the new fets in them they will probably be a bit faster
here are a few vids....
http://www.youtube.com/watch?v=HXfj4BiQiLM
http://www.youtube.com/watch?v=tuUHqLLnnpM
