micro-t CVD's problem
PA
if anyone has these, tell me what i am doing wrong.....
http://www.thetoyz.com/cart/thetoyz_...20MICRO%20BAJA
ok, so the axles are too short. they do not fit, and fall out insantly. what am i doing wrong.
i have looked closely at the package, and i received an extra set of tiny o-rings, tell me i am supposed to use them somewhere....
i am not a "noob" but i fail to see the resolve....
ON, CANADA
RE: micro-t CVD's problem
One set of o-rings go around the CVD bodies (in the grooves) to keep the CVD pins in, and the other set either goes inside the outdrive cup or is a spare set for the CVD body.
PA
ORIGINAL: dacaur
you didnt lose a bearing or bushing when you removed the old stuff did you?
SK, BANGLADESH
Oh boy! Integy..... i better not get started about this bunch of....... i am still pi**ed off. Sorry for that, but.........
Mini_Me is right. 3Racing has a good quality. Not the best there is but way better than integy!
PA
i have contacted "thetoyz.com" which is where i got them from, i am interested in seeing if i did something wrong....
