micro t diff HELP!!!!
Is there any upgrades for this micro t diff, because i striped two of them already and i dont want to buy another stock one. I am just running a Lipo batt and bearings.
SC
RE: micro t diff HELP!!!!
A few things you can do:
1. Order the 3Racing ball bearing tranny case- great upgrade, and spins like a charm
2. Place a small washer or shim between the bearing and the outdrive on the inside of the tranny case- nylon washers, or teflon, work great.
3. Break in each side independently by holding the wheel and half throttling for about 5 minutes. This will "seat" the outdrive gears to the diff gears, which are brass.
4. Periodically tighten all the tranny screws to keep it shimmed.
Good luck!
Good luck!
