MINI-T Help Please........
NJ
My stock servo on my Mini-T took a crap on me today. When i went to change it out with my servo from my RC18T, the servo saver from the Mini-T didnt fit the new servo. What's up with that? Please let me know what i need to fix this problem. Can i just get a new servo saver? And if so how do i know it's going to fit in that small space where the servo goes on the Mini-T? Link web site's too if possible. Thank guys
RE: MINI-T Help Please........
that's the crappy thing about the mini-t rtr. If you want to use a different servo, you have to change all the electronics. Your best bet is to get the same servo unless you want to change everything.
NJ
I was in the middle of changing everything. I wanna drop in my Mamba Comp set-up. The servo that came out didnt have a hex head to it. It had slines in it, but it was a small head and the one on the 18T had a fat head. But now that i think about it, shouldnt a new servo horn/saver work with the 18T servo?
yes or you might be able to open both servos and put the mini-t servo horn in the rc18t's but not 100% sure if those are changeable.... Usually they should be but yet i don't know you don't HAVE to use a servo saver... i don't use one and I have been fine and believe me i have flipped jumped etc many times. I also have the mamba if you have any problems let me know and good luck and have fun
