1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
I know what you're thinking...!
Reply
Old 11-19-2007, 11:36 PM
wilga12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default I know what you're thinking...!
Hey Guys
Really,... I know what you are thinking when I ask this question. But I did,... do some searches, and quite a bit of reading, but still didn't answer my question...
The Question:
If I switch out the "Stock" ESC from my Losi Mini Monster Baja to another that is Foward only would or could that have any effect on my total "Runtime" out of a charge..?? I'm still having 4-1/2 to 5 min times, with the new pack (1000 Mah) that came with my MMB.. Does this sound right, with the spur clearences checked...OK and the balance of the drivetrain good and free..?? The brushes and their condition don't cause me to be suspicious of them,.. there is plenty of unloaded rpm, and they sound very smooth and I never have to nudge the MMB after a full stop..??
The only component getting warm after a run is the battery itself...And that being only 120 degrees or so,...just good and warm in the palm of my hand...
I'm pretty new to "Electron Power" but this is not consistent with some of the times that other folks have stated with their MMB's
Thanks for your time ,...here ..................Dave..
wilga12 is offline
Old 11-20-2007, 12:20 AM
Mr. Mugen
Mr. Mugen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: I know what you're thinking...!
Is your slipper tightened to it's optimal position? If not then try that. Are you saying the car is reving up but not moving to the sound? (that was a lame question but to the point).
Mr. Mugen is offline
Old 11-20-2007, 12:37 AM
wilga12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No Mugen,.... I must not have done a good job of explaining...
My question is ...If I switched ESC's would or could that have an affect on my runtime outa' my pack,... which is still less than a dozen runs away from ,new..??
And then: Is only 4 or 5 mins, a realistic number of mins to get outa' a 1000 Mah Li-po pack,...With the aforementioned conditions on the drivetrain..??
Comprende..?? No,.. I'm not Hispanic...
..Thanks.....Dave..
wilga12 is offline
Old 11-20-2007, 01:11 AM
Mr. Mugen
Mr. Mugen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL.....thats ok Dave...it's me that was messed up there. A bigger esc will draw more ohms than a smaller one for sure. Check out the ohm draw on a micro esc and a 1/10 esc. You will see what I mean once you do. It may not have a great affect on run time though. IMO 6 mins run time is crappy. Then again those 1000mah packs are not that great either. If you want run time try a bigger pack like a 1400 or so. Kevin
Old 11-20-2007, 01:44 AM
wilga12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes I am in the process of doing exactly that....I've been eyeing some of the 1800-2150 Mah packs that come outa' Korea,.. the Poly-Quest...
Am I kinda' close to correct, in assuming that it will take 3 hours to charge a 2000Mah pack if my charger typically needs 1-1/2 hrs to charge my current 1000 Mah Li-po..??
Like I admitted earlier,...I'm still kinda' new to "Electron fuel",.. and all of it's habits....
Later.............................Dave..
wilga12 is offline
Old 11-20-2007, 04:49 AM
papa_smurf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get this pack from this site. This pack will give you about 20 to 30 mins of balls to the walls run time I think. I had it for a while now and I went through so much packs I lost count and it still works really good
papa_smurf is offline
Old 11-20-2007, 04:54 AM
wilga12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Papa Smurf...!
Did you happen to forget the link you were referring to..??
wilga12 is offline
Old 11-20-2007, 04:57 AM
papa_smurf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.b-p-p.com/proddetail.php?prod=k_TP2000_2s
hahahah I had it copied but I did not paste it.
Old 11-20-2007, 05:01 AM
wilga12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Partner...I'll check into it...
What particular car/truck are you running with this pack, that you like real well..??
wilga12 is offline
Old 11-20-2007, 05:05 AM
papa_smurf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
a stock mini lst that what you have right
Old 11-20-2007, 05:10 AM
wilga12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well,... same thing I guess,... Mine is a Mini Monster Baja
All The specs that I can find for the two are the same. like weight and physical dimensions...
wilga12 is offline
Old 11-20-2007, 05:12 AM
papa_smurf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With that batt. it will be faster too
Old 11-20-2007, 05:15 AM
wilga12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh Crimuny...!
I'll have to put in a pair of smaller pinions,.. I sure don't need any more speed
How long does it take your charger to do its job On a pack of that size..?..!
wilga12 is offline
papa_smurf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How are your gears holding up?
Old 11-20-2007, 05:19 AM
wilga12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So far so Good..!
wilga12 is offline
Old 11-20-2007, 05:22 AM
wilga12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How long does it take your charger to do it's job on a pack of that size..??
wilga12 is offline
Old 11-20-2007, 05:30 AM
papa_smurf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It takes about one hour or so to charge.
Old 11-20-2007, 05:34 AM
papa_smurf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have this charger
http://www.b-p-p.com/proddetail.php?prod=d_%23A2500
This charger is ment to be pluged in to a car batt. To use it in an outlet I went to raidoshak and showed them the charger and they gave me adpters to use with it.
Old 11-20-2007, 05:37 AM
wilga12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm surprised,... That's about what my charger is taking just to do my 1000 Mah pack...!
Well,.... I'm gonna call it a day, and hit the rack...
Thanks so much for all the good and specific info.
Later,........ P. Smurf...
wilga12 is offline
Old 11-20-2007, 05:45 AM
papa_smurf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no problem
I just wished people did this for me when I asked them stuff LOL
