good deal?
MN
good deal?
is this a good deal on ebay? the biding is at $100.
RC18MT
Losi "Synthesized" 27mhz Radio (No Crystals)
Mamba 25amp ESC & 6800kv Brushless Motor
MIP Steel Ball Diffs - Front & Rear
MIP CVDs - Front & Rear
ATM Black Composite/Nylon Lower Arms - Front & Rear
Threaded Aluminum GPM Long Travel Off-Road Shock Set
Stock Shock Set - Street & Carpet Setup With Upgrade Springs & Stock Springs
Aluminum Center Top Plate
Aluminum C-Hubs
Aluminum Axle Carrier/Knuckles - Front & Rear
Titanium Turnbuckles & Upgraded Ball Studs
Aluminum 12mm Wheel Adaptors For Touring Car Wheels
Black Steering Drag Link
Aluminum Servo Mount
3 Bodies - 2 Stock Painted & 1 Clear
And Misc Extra Parts
The Upgrade Parts Total Is Well Over $250. Plus The Radio System. Plus The RC18MT Itself. Well Over $500 Worth Of 1/18th Scale Fun.
You Will Need At Least One Part That Is Not Included In This Kit To Make It Work - Manufacturer Stock #21131 - The Small Screw That Connects The Front Knuckle To The C-Hub - $2.39 For All Four Screws - Only 2 Are Needed -
RC18MT
Aluminum C-Hubs
RE: good deal?
7.2v power isn't going to run much faster on a brushless vs. brushed system. You are going to want higher capacity cells and more voltage (8.4v, 11.1v) to take full advantage of the brushless capability.
By the way, a deal on ebay is never a good deal until the auction ends. Everything always looks like a good deal until the last 60 seconds. Pretty much why I always deal in BIN's only. If it ends for $100 with $20 shipping then I think you got a good deal, sure. Typically not a good idea to publish an active auction that you are trying to get a good deal on because you might bring more bidders to the auction. You should keep those to yourself. I found that auction in about 5 seconds by searching for the keywords you provided.
You an always use completed auctions as a good way to see if something is a good deal. See what others have paid and make the decision for yourself.
IL
RE: good deal?
Yeah I'd say its a good deal also , but like was stated before , its gonna go up alot from 100 dollars . I'd say at least 150 if not more by the end of the auction .
