RC18 & 7C Packs
RC18 & 7C Packs
after installing a dp spur cover it was impossible for my 7C pack to fit (arranged in this order - ===| ), so i was going to dremel the cover to fit. after taking it all apart, there is no way i can get it to fit w/ the cover as there is chassis flex without the cover in - the 7C pack is too long. anybody else have this problem? are all the 7C packs extremely tight in a RC18?
RE: RC18 & 7C Packs
Pretty much. especially with that gear cover.
Consider moving one of the cells to the top of the packif you want 7cells and wanna stick to nimh.
RE: RC18 & 7C Packs
ORIGINAL: rustlerbasher
without the gear cover... a 7 cell will still fit in a flat arrangement right?
CA
RE: RC18 & 7C Packs
yeha i think i may go with a stacked pattern too... ill just have to dremel the battery hold down thing
RE: RC18 & 7C Packs
My 7 cell pack is tight but it does fit without flexing or needing mods to the strap. I bought an intellect pack and it had a plastic cap at the end where the wire comes out, that didn't fit so I had to cut it off and retape the cells up. If yours is to tight to get the strap on you can raise one of the hold down screws and loop the strap around the threads and that will give you another 1/16th" or so.
PA
RE: RC18 & 7C Packs
just for peice of mind... The stock electronics and motor in the rc18mt will handle 8.4volts right? btw, i just ordered the stacked 7 cell Elite pack from thetoyz. and im just going to dremel the battery STRAP. lol
CA
RE: RC18 & 7C Packs
