Ok, this is really gettin annoing
CA
I have just installed a gear cover for my 18MT, and was trying it out with my new Dirt Hawgz tires when I am driving around and hear the dreaded, WWANNNNNNNNNNNAH, of a snapped shaft, now I can rule out rocks in the gear since I barely drove it lately, any clues as this is getting past annoing, I am to woried to upgrade to a different motor for the fear that it will snap as well, I had the mesh a little on the loose side to play it safe, diffs were loose, any clues, thanks
CA
RE: Ok, this is really gettin annoing
Bump, 23 hits and no replies, anyone got a clue, e-mailed assocated, have yet to get an answer, in the mean time, anyone got ANY clue[&:]
IL
So you snapped ANOTHER motor shaft ? Are you sure the center diveshaft is straight ? Maybe the spur gear is moving around and causing binding ?
I ran the stock motor for 2 months , then a Baja motor for 3 more , went too a Mamba system over a year ago and have ran mine VERY hard but never snapped a motor shaft ......
Maybe the gear mesh is changing from hard hits ? Mine was doing this for a while till I loctited the motor screws
CA
ORIGINAL: KRO
ORIGINAL: bigtreds
are the hawgs for 1/18th or 1/10th?
