Trinity Now 1st Impression
#376
VA
RE: Trinity Now 1st Impression
ORIGINAL: Silverfang
As far as this truggy and breakage. I myself have broken a few parts, but over all after a few months of bashing it every thing is holding up well. Out of the box this truggy is capable of going 40 mph and it is only a 1/16 scale. Ever hit something with your real car? I have seen what a 20 mph collishion can do to a real car and it can be pretty bad. So please keep in mind that the speed of this truggy is HUGE for its size. I can out run Jato's (2.5) tmaxx 3.3 and revos with this thing stock. So if you break an A arm or shater a body after rolling or hitting something, take in to account how fast you were going. I bash around my front yard jump roots of the trees run over rocks through mud dirt and basicaly use it as a offroad vehicle. Every thing has held up for over 2 months. I have bent the front shock tower and broke the body, but the hit I took should have broken WAY more than that.
These are just my openions. I was not there for anyone else's parts brakage so I don't know what happened. I am not trying to make any one mad or call any one a lier. Just saying that I love this truggy and I think it is over all a great rig. As far as parts go A main and Tower (I called them) have both siad they plan on keeping parts for this thing in stock reguraly. They are just wating on the manufacturer (not trinity) to send them.
Oh I forgot mine is not stock. I do have the optional front metal uprights, but that is all.
#377
I agree I'm done. I should have bought a Photon, which I found out is fully supported by a local hobby shop, but no. I didn't want some off shore knockoff. What did I get? an offshore knockoff. And no, Photon arms are too short. This is BS. I love trinitys excuses also. China shuts down for a month, blah, blah .............
#378
NJ
I contacted Trinity again about my broken parts, their advise was to buy the aluminum optional parts-but you guys are right, 15 and 29 dollars for options that are not even available, maybe we should be boiling the parts first then installing them otherwise this becomes too expensive, I can be driving a Revo for 400 dollars
#379
Ok, so I go to my local hobby store that supports the Photon. I buy the dogbones for a Vulcan and they fit. (about 6mm shorter.) with the upper camber links tightened all the way camber is OK. I had to trim down the toe links to get the toe right. Now, (Ughh) how upside down am I?? They had Photon SE's on sale for $170.00 I paid A-main $200.00 plus shipping. Another $70.00 in parts so that makes me $100.00 upside down on something i still can't get parts for. Then I go to charge the battery and it yellow lights. Trinity is even worse tha Kyosho California. I am way passed PO'ed. Don't bother boiling the parts. Wrong material.
#381
Boiling parts, actually called "moisture conditioning" is a temp fix. Any water you put in will eventually dry out. It does work well with Traxxas parts anf HPI which use a glass filled nylon. I also analyzed the NOW parts and they are over a 50% carbon load. Which is why they are so brittle, in addition they are shot way over heated adding to the problem. Check out a broken NOW part, they are full of voids from bad (china) processing. Actually I shouldn't blame China, they will make parts exactly the way you spec them. If you leave them to thier own methods, well. You get NOW parts.
#382
NJ
Im going to get the alum parts and deck this thing, if it breaks again after normal runs, Im putting it on ebay but this thing is fast and nice to drive.
Anybody figure out what wheels/tires will fit with 12mm adaptors (pin to hex) Trinity sells for these things.
#383
IL
I have a set of Mini Inferno ST wheels coming and I will post if they fit .
If you have a set of 12mm adapters then any TC wheel should fit , maybe some RPM 2.2 rims with some proline pin tires ? Or road rage II's ?
#384
NJ
Im looking for premounted wheels and tires that people would think would improve handling, something in 12mm hex, cant find any good ones. I am not familiair with the rpm but tower says they are 12.7mm, I guess that must be a mistake
#385
IL
Yes they should be 12mm , its kinda the standard for 1/10 wheels .
I just test fit a set of Mini Inferno buggy wheels and they fit no problem , but look small . The Mini Inferno ST wheels are bigger and wider so they shpould work out great .
Tamiya has some tires that look like they would fit the stock wheels , I think they are for the High Lift truck .
#387
NJ
Do you think it will make sense to drench the plastic parts in WD40 and let them sit, will those make the parts more durable? IMO the petroleum spirits in WD40 will degrade plastics & rubber over time, won't be too surprised if they grow hairline cracks & fractures. Trying to figure out how to keep those plastic part from breaking.
#388
IL
No , I dont think that would do anything . I would get the alloy front uprights (c hubs) and alloy rear bearing carriers and BOIL the rest of the plastic in water for 30 minutes . (full on rolling boil , dont worry they wont melt) Be careful not too let the water boil away !
Then drain the water and let the parts cool slowly , I have found this works very well and I havent broken an a arm since .
I got my 3 Racing Mini Vendetta ST wheels and they bolt right on no problems ! Look killer and LOTS more traction than the stockers have . But they are pin tires so they are gonna wear quick on anything except dirt or carpet .
But good news is if you find a set of wheels that fit the Mini Inferno ST they should fit the NOW also !
I have a set of Mini Inferno ST CVD's coming and I will post if they work with the ST arms on the NOW . ( a whole set of CVD's and alloy arms for the Mini Inferno ST cost as much as just the Trinity alloy a arms by themselves) !
#389
NJ
Can you send me links for the wheels you got? is this what you got?
http://www.3racing.com.hk/x_descript...ducts_key=8654
I have metal arms now, the hub carrier cracked last week, ordered the last set from Amain and installed them, the speed on this is great but traction is poor, if I could only get a nice set of road rage wheels on a 12mm hex wheel, that might solve the problem
#390
IL
Yep , those are the wheels . They really change the look of the truck and hook up crazy on my living room carpet .
If you bought a set and wore them down I bet they would be good on the street , that or get the 12mm adapters for the Mini Inferno and get some 1/10 wheels .
But I bet they are smaller than the 3 Racing ones .
#391
NJ
I just picked them up on ebay for 12.99 and 3.25 shipping, hopefully it is not a bad deal. They also come in black but will have to order those from HK.
#392
IL
I know , I wanted black too ! But oh well .
They seem to be great so far , they dont balloon up alot either and are glued too the rims very well .
Should have the Mini Inferno ST CVD's Mon or Tuesday , hopefully they will work with the ST arms . They will make the Now about a 1/2 inch wider .
#393
MI
I've had same problems you guys have with finding parts. I went in lhs and didn't have any luck creating something that might work. When I do run into something I'll post it. I just wish I'd created my front bumper BEFORE I crashed it to where ca glue couldn't temparily fix it. C hub and steering knuckle, thats my weakness.
#394
My Feedback: (23)
WI
Just thought I'd let you guys know that I installed the SideWinder 4600 combo in my now and its complete overkill. I just ordered the mini quake 540 mount and modded the chassis to make it fit and it did. It flips with the tap of the throttle and is going alot faster than stock. I'd have to guess its hitting around 50mph or more. Its hard to keep the front wheels on the ground at any speed and the 3s lipo hasnt shown any signs of taking a crap yet. The diffs are holding which is good so I really cant ask for much more.
#395
MI
Hey Takedown! I can imagine that was crazy fast. You sound like quite the modifier. Are you still using stock front end parts? ie. c hub and steering knuckles. I'm not having any luck finding replacement parts so I like many others are trying to find other mods or parts that will work. Any help or ideas would be appreciated.
#398
Has anyone had problems with the tires running out? Horrible vibration.
Mine runs for a couple of minutes, then the radio loses contact. Any hints?
I tried looking thru this forum, I'm sure these issues have been addressed, but I couldn't find it.
#399
My Feedback: (23)
WI
ORIGINAL: mrskascook
Replacement parts...
C-hubs- http://www3.towerhobbies.com/cgi-bin...?&I=LXPDB1&P=Z
Steering knuckles- http://www3.towerhobbies.com/cgi-bin...?&I=LXPDB4&P=Z
The whole parts listing is here- http://www3.towerhobbies.com/cgi-bin...I=TRIC9015&P=Z
