OFFICIAL RC18MT/B/T THREAD
#426
CA
RE: OFFICIAL RC18MT/B/T THREAD
ORIGINAL: rc-junky007
well like in the center and dogbones to each diff and elecrics in front wih a saddle pack
#427
CA
ok, well, have a heatsink on my motor for cooling purposes, been doin good, plannin on updating the track, lol, to many rocks..... things like that, er, plans, get dems later[], NOT VERY MANY JUMPS, OK!!!!!!!!! (ya, sis says she "is taking over designing it" oh brother, ok, NM else, thinkin of getting a flear shell and painting it[8D]
#428
ON, CANADA
So... im going to replace my shocks, and I cant seem to get the bottom off of the truck. The top uses a hex screw, but how does this bottom come off? This is for the front shocks, does it just pop off? I was scared to try that in fear of breaking it--- thnx!
#429
PA
Yes, the bottoms will pop off theball stud. Just be careful about where you are putting your brace hand, it takes a good amount of force to get them off. Good luck.
#430
My Feedback: (36)
I've been using my [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLMR6&P=7]ball link pliers[/link] from my helicopters to remove mine. Works really well.
#431
PA
actually, if you already have the tops off just let the shock hang to the bottom and pry it upwards from there. It will pop right off. I really like that tool though...I just ordered one, thanks for the link ptgarcia!!
#433
ORIGINAL: AutoXMan
So I have been bored with the RC18B so I was thinking of going brushless and lipo on it. I already have about 8 1500 ma 3 cell batteries so I am thikning of going with the mamba 6800 because it is dirt cheap right now.
I will shim the diffs and go for the MIP superdiffs, I am assuming I will need 2 sets of these? http://www3.towerhobbies.com/cgi-bin...&I=LXKBC2&P=ML
I hate the look of the RPM bumper and I am a very good driver so I won't be crashing into stuff (I run in a huge open area). I will get the RPM arms though because I like RPM quality components.
If I do put this on my 18B what gearing is a good starting point for 6800 and 3S lipo?
I may not put the system on the RC18B because I have a Thunder Tige rmini that has 10th scale diffs on it and will better handle brushless but it is 2WD so I am not sure [&:]
Thanks in advance.
*edit* oh and I have to get CVD's because I hate the dogbone clicking up front ugh might as well go with the thunder tiger.
Thanks in advance.
#434
PA
The plastic diff outdrives on the stock diffs are what goes those and the gears themselves. would go with the Super diffs and some new gears. If you shim your diff well enough you shouldn't have much gear problems.
#435
ORIGINAL: maybelater29
#436
Hi, today I am installing the mamba Comp system on my RC18B, can anyone tell me were is a good place to put the mamba esc switch in the 18b
thanks in advance for your time.
#437
CT
ORIGINAL: AutoXMan
Thanks man they opened a local 1/18th scale track I plan on using my 18b stock for awhile then upgrade to brushless.
i've heard of a road course for 1/18th scale that gets setup in an indoor soccer field in Fairfield too. that's pretty close to trumbull. i'm going to go check it out in a couple of weeks.
#438
My Feedback: (36)
ORIGINAL: marcialsuarez
I used double-sided tape and mounted mine to the top plate, just forward of the motor.
#439
CA
ORIGINAL: NitroBobby
i'm in CT too, where are you going to race? there's a track in Oakville at Pin Shop Hobbies that i race on. it's a 1/18th scale high banked carpet oval. i race the mini-slider but there's also an rc18t class. no brushless though. there's also a stock rc18r class.
ORIGINAL: AutoXMan
#440
ORIGINAL: AutoXMan
#441
CA
ok, in a delema, can ANYONE come up with a track plan for me, must have 6' plus lanes, and leave about .5' total for the lane markers, er, not to many jumps or turns, you have a 45X 35 (45 X 45 is allowed), PLZ state specs on it, tks alot, calvino
#442
IL
#443
CA
ORIGINAL: KRO
Here is my track layout that I run , its not too technical so you can go pretty fast , I have 2 single jumps , 1 big double jumps a whoop section and 2 berms I run 1/8 monster trucks on it so its plenty big for the smaller cars .....
#445
ORIGINAL: calvino
tks, ya, looks fun, hard to design one out here, lol, sis wants a jump over a lane, i want this, she wants that..... oh boy, tons of "fun"
ORIGINAL: KRO
#446
IL
nice and how much is the pipe you used there???? like it, got any vids of your car on it
Sorry no vids cause no vid cam []
#447
CA
ORIGINAL: KRO
The drainage tile was 30.00 for a 100ft roll , I am using a little over 200ft .
#448
NY
Its been a while since I last drove my 18MT, probably since august when the ecs took a dump. I don't get what happened the truck just stopped moving so I took it inside and when I went to turn it on again the esc ad the battery stated smoking and burnt. What could have caused that to happen ? I minaswell share a pic.
#449
CA
ORIGINAL: Art91
#450
IL
what to make the lane markers with, KRO, what size pipe did you use?? , I am thinkin 2" for $$$ reasons???
