OFFICIAL RC18MT/B/T THREAD
#2301
CA
RE: OFFICIAL RC18MT/B/T THREAD
check thwetoyz they have a giant selection for rc18t stuff.. just type in rc18t servo and you should find the saver its like 3$
#2302
NJ
I tried that motor in my Mini-T. No lie it lasted about 5 minutes. The end bell popped off and the motor was all over the street. That was the first time I tried going cheap on a brushless and I'll never do it again. Maybe I got a defective motor because I have read that a lot of people are having good luck with theirs but it's nothing but Mamba for me baby. I've delt with Castle Creations for about 3 years now. I've had nothing go wrong that wasn't my fault and even with that, I've sent back 2 ESC and 1 Motor, didn't pay a dime.
#2303
CA
do you guys think that the aluminum steering assembly will take more slop out instead of a draglink..
i mean i altready have a draglink but it is worn down quite a lot.. and it creates slopbut i guess tat the plastic steering does also..
#2305
ok, I must be new or something. The Super MIP Diff instructions mention putting the orange grease on the 'small' thrust balls? Where are these small thrust balls?
I picked up the AE Factory Team Carbide Diff Balls x 8, and thought that was all that would needed. Do I have to take apart my stock Diff to get these 'small' thrust balls to use with the MIP Super Diff? Tx.
#2306
NJ
The Thrust balls should be with the MIP kit. I know they were when I got my MIP diff for my Mini-T. But after a few break downs of the dif I slowly lost a few of them and now dont really see a difference with or without them.
#2307
I got em out (from the stock plastic diff) with a mini screwdriver. There were 7 of the lil buggers.
No mini thrust balls came with these Super MIP Diffs.
I was hoping I would not have to molest the stock diffs.
#2309
Thanks.
Another ques... do I use the original black thrust spring, or the small one included with the Super MIPs? It says 'Use standard spring support on thrust side' but want to be sure, otherwise why would they bother including a spring?
#2310
CA
use the spring, without the diff is a total PAAAAAAIN to work with (yes been there 100% know that), i used the stuff the super diff came with and have had 0 problems[8D]
#2311
My Feedback: (81)
VA
YEAH!! My 18R's arrived today These things are sweet! I can' wait to run them. At least now I can get the deminsions of the battery slot and start looking for the right LiPo.
#2312
VA
MORNINGSTAR sorry for geting back to you so late. So if I bought the motor would I have to bouy something el's or could I just make it run?????
#2313
I have the DP Drag Link, but is it even needed now that I have the 3racing aluminum steering assembly?
Or should I use the DP Drag Link together with the aluminum steering assembly?
tx
tx
#2314
CA
use them together.. it will make it twice as good..
i am getting a dp draglink on my next order and then the order after that i will get the akum steering
#2315
TX
hey oldzy are you building a factory team kit or upgrading one of the rtr's? the FT kit comes with a hitex servo saver. Also you will need to call hitec and get them to send you a longer screw to use with the 65mg servo (unless you manage to find one in a store... if you do then you are amazing.
#2317
TX
you'd have to get 100 first, and how would that be a difference than the LHS selling tiny screws for 2-3 bucks a pack (which is usually 2-4 screws) its a mad ripoff but damnit I need em now so I pay.
#2319
TX
you like that swang hobby deal Bob? Might chunk that in my wifes mini-baja just to get rid of the garbage losi stock electronics. That and once she sees my mongoose powered rc18b shes gunna be piiiiiiisssssssst
#2323
CA
i am trying to install the diffs on my rc18t and i forgot whicvh way they go in.. which is the stock location for the diffs. like which side does the gear go on etc..
thanks
thanks
#2324
ORIGINAL: Derigor
What size/length screw is needed? Anywhere on feebay to find it?
Tx.
#2325
ORIGINAL: maxxin2.5
thanks
thanks
