Micro Desert Truck
GA
RE: Micro Desert Truck
I'd have one if it was 4wd. I have a Micro-T, but I don't see the point in buying another one unless the new one is better, ie, 4wd.
1/36 4wd would be awesome indoors.
i hav one and love it. iv put on ball bearings, but im waiting to get threaded axles. with the longer wheel base you can put the battery between the esc and the rear shock tower. that way you only need to take off the body to change the battery.
TX
Thanks guys.
walkingcarpet900 - This is my first Micro, so I can't compare it to anything.
nitrosportsandrunner - Sweet, I can't wait to start hopping this thing up.
CA
I'd take my micro-b over it cuz the b/t turns better and stability isn't really an issue cuz i run on flat carpet and hardwood floors. Also, the micro-b/t battery time is better. But whatever floats ur boat. I want to buy some desert wheels and tires for my micro-b
ORIGINAL: bigairlife
the desert truck turns much better
since it has a longer wheelbase
and is wider
you have never had your micro flip before? mine flips plenty on carpet if i turn in fast
they all use the same battery
all have the same transmission
all have same diameter tires
so where on earth would you get that the battery time is better
WA
the DT doesnt turn nearly as sharp as the micro b. the longer wheelbase makes it harder to turn sharper btw...and the micro b is lighter putting less pull on the motor so it makes it faster and have longer battery life. i have a micro t and a micro DT.
i have the lipo in both and the micro t will wheelie on comand and the DT doesnt wheelie at all. the micro t is faster and has more acceleration and still gets better running times.
i love my DT because it handles the jumps better then the micro but i like the micro because of its speed and acceleration...
the micro is hard to handle because of the insane speed...i guess thats just my driving..lol
they both hold up very well and i have not broken anything yet.
IL
Boy are you lucky. Something in my differential is either stripped or messed up. There is a differential on its way. It was ordered last week sometime and still has not showed up![:@] . It has been broke for sometime now and i am needing to get it fixed. I also want to get a atomic bb moter and a lipo. I know that will increase the speed, and the run time. My question is how much faster will it go? And how much longer will the run times be?
WA
i heard the atomic bb is just the same as the stock motor. but the lipo will tripple ur run times and have some seriously noticble power gains.
ya i had both stock and atomic bb
i thot bb was ball bearing
so i was all like
OMG 10$ for a ball bearing motor
but turns out it was brash bushing =P
ya i know its a bit bigger
but seriously it cant alter the runtimes by much
maybe a minute or two
if i'd know bout the dt
i would have gotten it because it handles better/ and is more stable in jumps
so i was all like
CA
ORIGINAL: walkingcarpet900
so i was all like
so i was all like
WA
well just going from bushings to ball bearings has givin me 2.5-3 more minutes of run time...yeah the difference from the micro t to the DT is probably 1.5-2 mins...i like driving them both...i cant decide which is the best.
I just got the DT last week. What a riot to drive. Im fairly new to RC, but already have a pretty well upgraded rustler so you can say I have the bug bad. After my Rustler has a few more upgrades I can turn to the DT.
IL
I just converted my Micro T into a Micro DT and I like the DT MUCH better ! The T does turn tighter but not enough to matter for the added benefits of the longer wheelbase and much cooler looking wheels/body IMO .
My DT will still wheelie but not like the T/B will , but I am running the Atomic motor and a 200mAh LiPo battery and the 3 Racing gearbox . I kinda like that better too , instead of having to be VERY careful when getting into the throttle to accellerate (my T would just flip over or "diff out" and get unstable) now if you roll on the power it peels out and takes off .
WA
hmm...how do you like the atomic motor?? i heard it is nothing better then the stock motor? and where did you get the larger lipo....what are the advangtages of the gearbox and where did you get that as well?
IL
I bought the motor and gearbox from TheToyz.com , the LiPo is from AeroNuts .
Here is the LiPo , its a tight fit (plenty of room in the DT), there is no battery cutoff , and you need a balancing charger that will charge at low amperage .
[link=http://www.aero-nuts.com/product_info.php?cPath=32_56&products_id=433]Micro T/B/DT Battery[/link]
Here is the 3 Racing gearbox and Atomic motor (which is faster and has more torque than the stock motor IMO)
[link=http://thetoyz.com/cart/thetoyz_details.lasso?id=9176&cat_name=]3 Racing Gearbox[/link]
[link=http://thetoyz.com/cart/thetoyz_details.lasso?id=8619&cat_name=]Atomic Motor [/link]
I just ordered the team losi lipo/charger combo for the micro desert truck. Is there anything else i need to do beside just install the new battery and run it?
Defm
Defm
IL
I just installed the Losi Excelorin brushless system in my DT , its not a whole lot faster than the Atomic motor , but now it wheelies like before and I ran 25-30 minutes and the pack still had juice in it . Put in the JR SM22 servo and the micro receiver from my Trinity NOW. Finally got some threaded axels too !
no bearings yet. Does that make it roll better when you let off the gas? Now the back wheels kinda lock up when you let off the gas and spin it out. Those are pretty cheap right?
Defm
Defm
