Problems with diffs, are they too loose?
NC
I finished my RC18T build and put in a mamba system. When I hold the car in the air and pull the throttle only the rear wheels spin, and one front wheel barely spins. When I sit the car on the ground it barely moves even at full throttle. I think my diffs are too loose as I was afraid to over tighten them. Is this my problem, should I tighten them up? What are the worries of over tightening?
kent_man
kent_man
RE: Problems with diffs, are they too loose?
Snug them up and try again. Do not overtighten just do it in testing steps. Try a little more each time until it's wherr you like it.
CA
ORIGINAL: kent_man
kent_man
kent_man
