Micro-t, Baja, Desert Truck Questions
Hey, just a couple of quick questions.
What kids of speeds should be expected brushless?
Are these durable?
What hop-ups are necessary to make it reliable if it already isn't?
Can the 20 minute quick charger charge the lipo batt optional pack?
Thanks in advance! I am really considering picking up 2 of these and making them brushless, if i don't i will get 2 1/18th scale mini baja's.
Are these durable?
RE: Micro-t, Baja, Desert Truck Questions
Alot faster then the stock brushed motors.
Are these durable?
Depends on how you drive them.
It is a pretty reliable in the stock form.
NO, the quick charger will not charge the lipo pack, you will need the lipo charger to.
Are these durable?
Smaller is better I would get the 1/36 DT. These look so cool racing around with lippo and brushless installed. I will buy another soon. Now as far as durability goes they are durable. If you take these outside and run them at full speed on the street and driveway jumping off curbs and small jumps you will have a lot of fun and they will easily take it with no problems. They are fun off road to if you know where to run them away from big rocks and such. But if you run it full speed inside your kitchen and slam it into a wall or jump it down a flight of stairs at full speed well........ Also there are tons and tons of hop ups for it to make it very durable and very fast. Yes the price is worth it to make these cool.
