Anyone used this lipo pack for rc18mt?
NJ
Hi anyone has used this lipo pack from maxamps? http://www.maxamps.com/Lipo-2100-74-Pack.htm ? does it fit perfectly? if not how much dremel work is required?? Thanks a lot.
My Feedback: (36)
RE: Anyone used this lipo pack for rc18mt?
I have a couple 2100 mAh Thunder Power packs I can try for you. They appear to be the same size as that MaxAmps pack. That's a standard layout for the 2100 mAh cells.
NJ
hey.. how is hyperion litestorm compared to maxamps battery?? which is better?
which is better quality? http://www.maxamps.com/Lipo-2100-74-Pack.htm OR 1800 mah of http://www.b-p-p.com/proddetail.php?prod=d_H1800VX ?? Thanks a lot
I personally use lite storms in lots of my cars and planes. They are awesome! Up there with TP or better. I have had good luck with mine. I carshed my stryker into the ice at about 90mph and mushroomed a 2100 pack and straightened it out and still fly it. I know this is not recommended but it is just a testament to the quality of the pack.
NJ
i was thinking if this 2100 pack http://www.maxamps.com/Lipo-2100-74-Pack.htm is too big, i would dremel few millimeters off truck. But if litestorm is better than maxamps, thne i will just go with litestorm pack.
NJ
the litestorm 1800mah does fit r18mt.. i now need to know which pack is better, better wires and all.. "maxamps" or "hyperion litestorm" .. like i said http://www.maxamps.com/Lipo-2100-74-Pack.htm OR 1800 mah of http://www.b-p-p.com/proddetail.php?prod=d_H1800VX ?? it would be awesome if anyone has experience with both brands and types of batteries. someone told me that maxamps will fit with mininum dremel work.
