More ground clearance?
IL
Hi guys,
I want to know how to make my vendetta buggy have more ground clearance? My friend and i were driving our minis in the woods. He has a mini t and he made it over a 1-2 inch dirt pile, but i got high centered.
Can some one help?
Thanks savycharlie
Can some one help?
Thanks savycharlie
RE: More ground clearance?
heavier oil, stiffer springs, more preaload, diff shock position
make it so the shocks are standing up
if it still doesn work
put either green or blue springs
then more preaload as you need it
if it feels too bouncy
put heavier oil
put heavier oil
how far the springs are pushed down
i have vendetta st
and i use 90wt oil and yellow springs
and it is perfect for offroading
since you have the buggy i would put
maybe more preload
heres the spacers... u put it on the shock
before the collar of the shock
http://www3.towerhobbies.com/cgi-bin...?&I=LXMSC4&P=7
there the things on the bottom left in the picture above ^^
i have vendetta st
maybe more preload
