xray m18mt
xray m18mt
i just put a 3s lipo in my xray and the truck is uncontrolable, i was thinking of going with a 2s lipo or maybe even a nihm pack.i have the mamba 25 at its lowest power setting but you just can't drive it,no traction.
RE: xray m18mt
What is the gearing and motor Kv?
Changing from 7.4v to 11.1v is quite a change, you may want to use a smaller pinion and/or smaller wheels/tires with more grip (like the m18t).
On hard compound stock 70mm tyres I found it a bit of a handful and have to feed the power in carefully to maintain grip. Make sure the ESC throttle endpoints match your Tx throttle endpoints, for a full range and resolution, you don't want your throttle to feel like a switch (full on or off), making it hard to manage RPM in the air when jumping. Particularly with the larger inertia of the M18MT wheels, if you don't have fin control over the wheel RPM in a jump then the truck is more likely to flip or endo nose first over.
WA
RE: xray m18mt
A dirt track with dust right? Not like a mudbog or rocky ground?
You will have more fun seeking tires of a different design. Something in a mini-pin. Or this:
Micro Monster Truck Tire & Insert - Thrax (4+4) # 389620
RE: xray m18mt
i have the trinity NOW with pretty much the same set up in the xray and it drives so much better.a soon as i get up to full speed the xray just spins out. don't get me wrong this is a great truck i just think i need to slow it down a bit
RE: xray m18mt
i just took out my brushless set up and put in the xray power pack that came with the kit and its a blast to drive .not as fast as the NOW but its pretty fast for a mini. i will get different tires like u said . thanks
