Battery
Battery
Hey everyone!
I just finished rebuilding my diffs, and now i have a small problem, my lipo has some issues
I have an Align 2100mah 20C batt that gives me loads of power (balloons tires)
I also have polyquest 1600mah 20C batt that has some problems
Now, with the polyquest, i dont know why it doesnt have enough power, it goes to very little power in almost 15 seconds... like slower than stock power
By the way, i have an RC18MT
Diggity Designs full CF chassis
MIP Diffs
MIP CVDs
Lunsford Titanium Turnbuckles
Mamba25 ESC
Mamba 6700kx motor
I dont know what to do...
Now my question is, can i save this battery? And if not what battery do you guys suggest to put in the DD chassis (make sure it fits) if you can find one with the same size as the polyquest that would be awesome!
I want to stay 3cell at least 20C, at least 1600mah
Thanks so much guys!
Give me all the options! Forget my requests! List em all!
Thanks again!!!!
MIP Diffs
MIP CVDs
Mamba25 ESC
Mamba 6700kx motor
Thanks again!!!!
RE: Battery
no no, this problem started after i left the batt alone for about 6 months at full charge...
So i dunno
Could it be the connectors? They may have gunk on em?
So i dunno
FL
RE: Battery
it's my understanding that storing lipo's at full charge will lose punch due to increased internal resistance. im not sure what exactly causes this, but that seems to be the consensus.
RE: Battery
So the battery is bye bye in essence...
If so, what battery is a good battery for INSANE speed... before this battery died i had alot of speed!
What is a good batt to fit in my chassis?
3 cell please!!!
3 cell please!!!
FL
RE: Battery
im guesssing its probably done. you might try cycling it a few times and see if it gets any better....
i don't have your chassis so idk for sure. measure your battery tray and then check out [link=http://www.hobbycity.com/hobbycity/store/uh_listCategoriesAndProducts.asp?catname=25C+Disch arge&idCategory=240&ParentCat=85]hobbycity[/link]! the zippy & rhino stuff is jam up and dirt cheap! you pay more for shipping, but you'll still save a ton and they have it here in 4-5 days from china!
RE: Battery
Try these as well I bet you don't have to wait 5 days to get them.
Linky:
http://www.promatchracing.com/products.php?cat=21
That is a good deal.
Linky:
FL
RE: Battery
24.5x46x137mm fits in a rc18???
hobbycity has all sorts of cheap goodies! check out the BL stuff while you're there. my castle 4200 gave up the ghost this am, so i stuck my $14 4800kv hobbycity special in... i was doing complete backflips with MT tires @ 13/54! the thing was near silent too! freaky!
RE: Battery
I would stay with that same cell. The cells in that pack are enerland cells. A replacement that I know of would be flightpower. If you look around, you should be able to buy packs with the enerland 1600mah cell from enerland, polyquest, poly-rc, hyperion, flightpower, trakpower, and probably a couple I missed. They are the best of the best. Hobbycity packs are alright, I own a couple myself. Just stay away from maxamps!
OK
RE: Battery
You killed the batteries. If you run a lipo cell below 3.3V per cell, it will internally damage them, and make them have a very short if any runtime. Unfortunately you can't cycle them and bring them back to life.
When your running your car, and you think the battery might be going dead, take it out of the car and put it on the charger. You can also install a lipo cut-off, like the Novak Smart-Stop LiPo cut off, that will automatically cut the power going to the ESC when it senses its to low.
Hobby City is also a very good place for LiPo batts, like mentioned earlier. I have had several of the Zippy packs, with no problems at all.
I second the Max Amps, their stuff is junk, stay a way from it.
RE: Battery
Sounds good guys!
Im just reporting in to say my EFlite battery is INSANE! I got her for 25 bucks (1500mah 25C) and it rips!
My new problem is i installed steel diff gears in teh rear, and a alloy aluminum spur gear, and i shred the spur gear... anything you guys know that i can purcahse or use that WONT strip every pack of running?
Thanks!!
Thanks!!
