1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
OFFICIAL Detta ST THREAD **********
Reply
Old 10-15-2009, 07:33 PM
  #1601
jeppe317
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OFFICIAL Detta ST THREAD **********
can you any charger/balancers from hobbycity that have that run on ac, i need one i can use in the house. no more slamming hoods!
jeppe317 is offline
Old 10-15-2009, 09:40 PM
  #1602
jeppe317
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nvm that, the one i did find had terrible reviews, ill stick with the dtx
jeppe317 is offline
Old 10-18-2009, 07:37 PM
  #1603
jakesterama
jakesterama's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jakesterama
I rock these
http://cgi.ebay.com/2-x-25C-7-4V-180...item5635f55d10
Gadex (aka Action LiPo) is made by BYD, 2nd largest battery manufacturer in the world, and they work great!
Well, so much for them working great. I was on ~5th charge and when checked with my lipo meter one cell has gotten way under voltaged. Charger won't charge it anymore. I always balance charged them at 1C and stopped running as soon as they hit LVC Time to try out the Turnigy's!
jakesterama is offline
Old 10-20-2009, 05:31 PM
  #1604
kybowtie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Our indoor racing season has started, and I would like to try some different tires/wheels. I've read through the tire test forum that was posted, but I guess I'm a tad confused. The conditions will be tacky dirt, so the type of tire is not as important.
-Is there a tire/wheel that will fit the ST at this point, or does modifications need to be made for all applications other than stock, vendetta ST tires?
-I See JConcepts has a 2.2 wheel that measures 1.25" wide, but it is a beadlock wheel designed for the 1/16 revo. So it looks quite heavy with the 3mm screws that have to be installed. Plus it's quite expensive.
-Is there a tire that can be stretched over the stock wheel?
-Does the atomic wheel adapter allow the use of wheels that compare in size to the stock wheel?
kybowtie is offline
Old 10-20-2009, 08:30 PM
  #1605
Snipin_Willy
Snipin_Willy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I rock these
Ideally, you stop before you hit the LVC. LVC last resort. Dipping lipos into that low voltage range will weaken them and shorten the cycle life. Seems as you found this out the hard way.
Snipin_Willy is offline
Old 10-22-2009, 02:18 PM
  #1606
revo_sbs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
most to all 1/10 scale touring car wheels and tires will fit with the vendetta. As long as it has a 12mm hex you are good. Mini e-revo wheels are not to great on a vendetta.
revo_sbs is offline
Old 10-22-2009, 08:26 PM
  #1607
minimalistix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what is better for my buggy:
1. http://www3.towerhobbies.com/cgi-bin...?&I=LXLXY0&P=7
2. http://www3.towerhobbies.com/cgi-bin...?&I=LXTZN7&P=7
if you can tell me why will be good
Thank you
minimalistix is offline
Old 10-23-2009, 06:59 AM
  #1608
minimalistix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
and one more question if i buy:
http://www3.towerhobbies.com/cgi-bin...?&I=LXLXZ6&P=7
somebody can tell me inside the shock will have oil or i must buy separate oil ? if i must buy separate oil somebody can tell me good oil from towerhobby.
Thank you
Old 10-23-2009, 08:48 AM
  #1609
jakesterama
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Snipin_Willy
I know you want to avoid hard LVC where the ESC ceases to function, but I would stop when I started noticing loss in power, IE the power pull on the batteries was causing the voltage to drop to the LVC number, but the resting voltage was still above. I have heard this termed soft LVC, but it seems like there is some ambiguity. The cell voltages are 2.92/3.55 leading me to believe that the power delivery was not balanced very good and one cell was pulling harder than the other. I think if I could get that one cell's voltage back over 3 my charger would balance it and I might save the pack.
Quote:
ORIGINAL: minimalistix
Thank you
I have the aluminum knuckles on my buggy and the pivot balls on my ST and haven't had issues with either. I would say go with the cheaper solution and use the cash you save to buy spares.
Thank you
It states right on the page
Quote:
REQUIRES: Assembly following the included instructions sheet and shock oil of
modeler's choice - ASCC8072, ASCC8078, ASCC8073, ASCC8079, ASCC8074
I usually use 30 weight or equivalent but I just bash around the yard and on the street so if you are racing I don't know..
Old 10-23-2009, 09:54 AM
  #1610
minimalistix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what oil prefer for offroad settup have buggy + allu shocks what you think for 45wt ?
Old 10-23-2009, 04:23 PM
  #1611
goreyboggs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello, I use to have a vendetta st and now am wondering if I should get another. My main concern is about the screws that hold the tires on use to fall out on High traction surfaces. Is there an upgrade for this? I see the new vendetta has nut that hold the tires on but the st still has the same old screws. Any help would be great. Thanks!!
goreyboggs is offline
Old 10-23-2009, 05:25 PM
  #1612
Metallover
Metallover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: goreyboggs
washers and a small amount of threadlock
Metallover is offline
Old 10-23-2009, 05:34 PM
  #1613
Zinje
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats the problem i have now but can't seem to find washers small enough.
Zinje is offline
Old 10-23-2009, 05:43 PM
  #1614
Metallover
Metallover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Zinje
You can find smaller washers at your local hobby shop or on a hobby website like tower. Stock up, you may find you want more once you use them for the first time. The screws are 2.6mm btw.
Old 10-23-2009, 08:20 PM
  #1615
goreyboggs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool thanks I got another couple question one for ya, Do I put the washer inbetween the wheel and hub carrier? Also My track runs an open mini class. Do you think the vendetta st is the most competitive? Thanks again for the help.
Old 10-23-2009, 08:50 PM
  #1616
Snipin_Willy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It can be a good competitor, but x-ray might have you beat. Not like you see many of those out there because of the price, and unless you have a pro-drive behind any mini-wheel I doubt you'll see much difference in the competition. It'll come down to who's on all 4 wheels the most and who's doing the most cart-wheels.
No washer between the hub and wheel or hub and hex. Only between the wheel and nut.
Old 10-23-2009, 08:51 PM
  #1617
Metallover
Metallover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh whoops, I misread your fist post.
If the screws come out, then all you need is a very tiny drop of threadlock to hold the screws in. If the tires come off when the screws are still on, then you need washers. You would put the washer between the screw and the wheel so the wheel doesn't slip off.
Threadlock should be all you need.
Old 10-26-2009, 03:51 AM
  #1618
Zinje
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bought steel CVD's but i manage to strip one of the diff output joints.  Does anyone know where i can find steel ones?
Zinje is offline
Old 10-26-2009, 10:26 AM
  #1619
rc_racer123456
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just afew quick questions first i am going to my local ace hardward and i want to replace the screws that hold on the tires what size cap head screws do i need to get? secondly i found a pinion gear that will work on my dynamite c4 motor and not destroy the stock spur gear it is a 2mm 48p pinion my question is, is there another spur gearout there that i can use and run my regular pinion and not the new one i found? the reason i ask is because the one i founf=d will not be here until next week and i want to race this weekend, i read somewhere where someone was talking about some kind of spur gear conversion????? any help would be appreciated.
rc_racer123456 is offline
Old 10-26-2009, 11:47 AM
  #1620
Noff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zinje, you have a PM.
Noff is offline
Old 10-26-2009, 06:50 PM
  #1621
goreyboggs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone one here looking to sell a vendetta? If so drop me an email jeffgregoria@yahoo.com I would like to get one for next week. RTR or a roller it don't matterh
Old 10-28-2009, 11:36 AM
  #1622
mini-dude
mini-dude's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rc_racer123456
screw question = you won't find those screws readily ANYWHERE, other than through a hobby shopthat stocks DTX parts- as they're 2.6mm.
spur gear question = NO! you're better off sticking with the duratrax spur, and then finding an appropriate (metric) pitch pinion to mesh with it
mini-dude is offline
Old 10-28-2009, 04:15 PM
  #1623
revo_sbs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rc_racer123456,
How is that c4 motor holding up? IF I was you I would sell the c4 and buy either an ammo or medusa motor. I believe that the c4 has a can dimension of 20 and a shaft diameter of 2.3. With and ammo or medusa motor you will be able to get a can size of 28 and a shaft diameter of 3.2. Robinson makes a ton of metric 48p pinions that fit the 3.2mm shaft.
revo_sbs is offline
Old 11-07-2009, 10:14 PM
  #1624
Snipin_Willy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can't let this thread die, it's too important.
I'm picking up someones brushless Detta ST in a trade. Now when my nephew asks if he can drive mine I just let him wheel my loaner .
Old 11-07-2009, 10:54 PM
  #1625
hyperscorpic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alright, keep it alive by posting some pic
I just wish someone would make an alu bumper...the plastic one gets chewed up pretty bad bashing on concrete =p
hyperscorpic is offline
Reply
Display Modes
