atomicmods
RE: atomicmods
ORIGINAL: rustlerduster
i ordered a pair of those rims from atomic mods IM NOT A NEWBIE!!! and they wont fit on my micro t so wat do i do???
RE: atomicmods
Make sure they're not mini T rims... They should fit if they are made for the micro T. Also, if you are having trouble getting them on and it seems the shaft is not long enough, take a pair of pliers and hold the driveshaft outwards because there is some play between the dogbones and drive cups. If get the dogbone pushed over towards the rear hub the wheel should be able to go all the way onto the shaft. BUT if you ARE NOT A NEWBIE the second reasoning shouldn't be true...
I got some black rims from atomicmods for my micro T and they fit fine. I had a lipo and atomic bb motor too and the rear rims both got the middle ripped out because it had so much power...[>:]
