1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
M18 speeds?
Old 06-29-2008, 12:44 PM
supamagician
Default M18 speeds?
What are the stock speeds of the M18? (touring car) Also, how fast would it be with [link=http://www.atomicmods.com/Products/Reedy-ASC291-Mini-Modified-17-Turn-Motor__13428.aspx]this[/link] motor?
Old 06-29-2008, 01:10 PM
Irlsh
Irlsh's Avatar
Default RE: M18 speeds?
ORIGINAL: supamagician
stock speeds all based on gearing and battery factors. bu you want the best bang for you buckl get a speed 300 6v it will shock you.
Old 06-29-2008, 01:28 PM
supamagician
could you post up a link to that motor? Also, what kind of connector is on the batt. it comes with? I have a tamiya style plug on my charger, and have TRX plugs on my batteries, and I just put an adaptor on the charger to be able to charge my batts. Could I do that with the kind of plugs on the xray?
Old 06-29-2008, 01:34 PM
Mini_Me
Mini_Me's Avatar
You could (adapters). The only real big downfall of the trx other than their cost, is they are bigger. As far as a cleaner layout, you might like the Deans ultra plugs.
The motor you linked to would require a new esc. The m18 rtr comes with a esc that only meant for 180 size motors (smaller motor). If your wanting to go with higher speeds right away, you might want to look into getting the kit version of the m18 as so you can choose your own running equipment.
Old 06-29-2008, 01:37 PM
Irlsh
Irlsh's Avatar
oh he was talking about the kit rtr? i think its a waste of money unless u want to be entry level. you can get a kit model running for even cheaper. speed 300 v6 is only $12 bucks and a novak spy $50 and hitec 81mg $20 ish
Old 06-29-2008, 01:39 PM
supamagician
yeah but the kit is only 5 dollars less. if it was like 50 less I might consider it. could someone give me a link to that motor and an esc for it?
Old 06-29-2008, 01:44 PM
supamagician
could I put that stuff into a Micro RS4? what kind of speeds would I be looking at?
Old 06-29-2008, 01:49 PM
Mini_Me
Mini_Me's Avatar
Huh? Are you talking about total cost with equipment? Don't forget you are buying better quality equipment by buying it separately. The kit version should be near 95 dollars less.
Old 06-29-2008, 01:51 PM
supamagician
i was looking [link=http://www.atomicmods.com/Categories/XRAY-M18/Kits.aspx]here[/link] and its actually 15 less but still
Old 06-29-2008, 02:38 PM
Mini_Me
Mini_Me's Avatar
Your looking at the m18 pro. I meant the standard m18. The m18 rtr is a m18 based vehicle, not a m18 pro.
Old 06-29-2008, 03:42 PM
supamagician
Oh ok, I found what you were talking about. I think I am going to get this [link=http://rctoyzone.stores.yahoo.net/rs4mickitdod.html]Micro RS4 kit[/link], with this [link=http://www.atomicmods.com/Products/FUTABA-FUTK02-MAGNUM-2PL-27Mhz-AM-Digital-Transmitter__13783.aspx]radio, reciever, and servo[/link] and that motor and esc y'all were talking about.
Old 06-29-2008, 05:35 PM
supamagician
If I wanted to put the speed 300 into a Micro RS4 rtr, would I need to get a new esc? how fast would it be? would it destroy the car? lol
Old 06-29-2008, 06:10 PM
Mini_Me
Mini_Me's Avatar
The M18 kit can be had for the same price if you look around and handles better out of the box without having to purchase tons of upgrades.
Old 06-29-2008, 06:17 PM
supamagician
could you help me find the m18 dit at that price. I google xray m18 kit, and the cheapest I have found is 120
Old 06-29-2008, 06:32 PM
Mini_Me
Mini_Me's Avatar
See your PM.
Old 06-30-2008, 12:50 AM
supamagician
Ok thanks. What is the AE stock 370 motor. Will that just drop right into the xray, without having to put in another ESC? what speeds would that throw at me?
Old 06-30-2008, 02:10 AM
Mini_Me
Mini_Me's Avatar
You would want to buy the 42 tooth spur for a 370 motor. The kit comes with a 36 which is better suited for lower kvs and smaller motors. Also, the stock motor mount is meant only for 180 size motors. You can fit a 370, with it, but you will have to drill your own holes farther apart on the mount. Otherwise you will need to purchase an aluminum motor mount.
Old 06-30-2008, 02:19 AM
supamagician
How much is the AE motor nd the spur gear, and the motor mount. links to them would be appreciated
Old 06-30-2008, 02:31 AM
supamagician
Is this the motor I'm looking for? http://www3.towerhobbies.com/cgi-bin...&I=LXKCD0&P=ML
What kind of speeds does it have?
Old 06-30-2008, 07:26 AM
Mini_Me
Mini_Me's Avatar
Here are the links to the items:
[link="http://www.teamxray.com/teamxray/products/proddesc.php?prod_id=755&kategoria=&catName=Spur%20Gear%2042T%20/%2048"]Spur Gear 42T / 48 # 385742[/link]
[link=http://www.teamxray.com/teamxray/products/proddesc.php?prod_id=827&kategoria=&catName=Alu%20Motor%20Holder%20-%20Universal%20-%20Blue] Alu Motor Holder - Universal - Blue # 382021[/link]
