Vulcan 2 speed problems
i upgraded my vulcan with a 2 speed tranny... its kinda hard to setup as it changes everytime I run my car.. kinda strange
I have already opened the darn thing and check what makes it tick... Its not a clutch type... it has somekind of catch that lock on the screws bolted on the gear.... not a good design i guess...
THe main problem is the small spring than hold that locking mechanism.. When i start running the car.. it holds okay.. but as you run longer.. the shifting become shorter... during just in a single run you will have to make adjustments on the 2 speed...
has anyone had a chance to fix this problem?
here is my test run this morning.. you can see how abnormal the gear shifts...
[link]http://www.youtube.com/watch?v=TPhc5pVBtII[/link]
ah yeah.. there is another thing.. if you get the timing wrong on the 2 speed.. and shift longer.. there is a tendency to break the spur gear... I had broken 3 already.. just because of the wrong shifting...
RE: Vulcan 2 speed problems
got the 2 speed up and running.. need a real heck of tuning to get it to shift right... hehehe.. the toki motor has good power.. not close to a Picco Zero but did its job well with the 2 speed... tried to take some vids.. but it was a little late. kinda dark... ill try to take some tomorrow morning... see if the Vulcan will have a good run...
the metal gears really hold well... no more stripping problems....
[link]http://www.youtube.com/watch?v=Q1M-9_gFiEQ[/link]
yes finaly got the power on my Vulcan... 2 speed is working better... darn this little buggy goes really fast....
just finished breaking in.. got 5 tanks already... better try to push the this little engine...
[link]http://www.youtube.com/watch?v=GU4m9axSMac[/link]
