1/18 Losi Li-Po/Charger
http://www.horizonhobby.com/Products...rodId=LOSB9630
I'm thinking about getting that when I order my 1/18 Desert Truck since I need a new charger and battery. The Li-Po battery alone is $55 so for $10 extra I get a charger. Does it have a built in Li-Po cut-off or do I have to buy one separate since the Desert Truck Electronics don't have one built in?
CA
RE: 1/18 Losi Li-Po/Charger
this is what i read..
ESC and RECEIVER
The Mini-Desert Truck utilizes industry standard 3-wire electronics for easy setup and compatibility or customizing. The installed electronics are also compatible with a variety of batteries, including 6-cell mini packs and 2-cell LiPos.
ESC and RECEIVER
I know that it can handle it voltage wise I just need to know if either the battery or ESC/RX has a Li-Po cut-off.
