Micro-T cvd axels
RE: Micro-T cvd axels
What cvd's did you get? I bought the set of Integy cvd's and the pins fall out. Make sure to put a piece or tape or thin walled shrink wrap around them to retain the pins.
Also I found that they were too short. I fixed this by adding a small washer between the cvd and bearing to make the shaft go farther into the output.
Kevin
Kevin
Banned
CA
ORIGINAL: Mr. Mugen
Kevin
Kevin
IL
How are the pins retained in those? Integy uses a small O ring that rots faster than any other rubber I've seen.....which leads to pin falling out.
If you do loose the pin you can cut more from a sewing needle .
PA
i will ONLY use the 3R stainless steel ones since i have already ripped through ~ 4 pairs of the aluminum ones. the integy ones fit like crap, DO NOT buy them.
