Can the Liso Micro T go on grass?
Hi, I saw the liso micro t 1/36 today for the first time (new to everything.) It is $79.99. I saw on youtube folks using it on dirt and carpet. Can it be used in short grass? I wanted to use it at a park that has only grass. Thank you.
RE: Can the Liso Micro T go on grass?
no unless ur park put down miniature golf turf. the ground clearance is nowhere near enough they r mostly used on smooth dirt, pavement concrete and carpet Welcome to the hobby
what about the bigger cars? There was a baja one there but I can't remember the exact scale. It was mini I think, instead of micro.
Thanks for the welcome.
ORIGINAL: FloridaDude
as u probably know water and electronics dont mix well. but if ur careful u can just dont go through puddles unless u waterproff it. the baja u saw was probably a mini-t 1/18th scale. it can go on short grass but will not be to good since its not 4wd and ground clearance is still an issue. if u wanna go on grass get a losi mini mlst 4wd great ground clearance very strong as well as the AE RC18MT
just follow some of the steps listed in the "how to waterproof" thread. a little moisture might be ok from time to time. but i wouldnt take a chance. waterproof it and stay away from puddles and youll be just fine. ive never run one on that fake grass stuff but i cant see it being too much different than carpet so give it a shot.
