RC18T RPM arms losing pins?
MO
Hey guys...
I have a new set of RPM arms on the front of my 18T, and they're losing the pins that hold the caster blocks on. I have the retaining screws tight and where they need to be, but the pins still wiggle out...
I lost one of my FT aluminum dogbones last night because of this, so it has to stop... What am I doing wrong? Has anyone else had this problem?
Also, if it helps, it is and FT 18T, and the caster blocks and steering knuckles are GPM, along with stock suspension pins.
MO
RE: RC18T RPM arms losing pins?
I made my own solution... I took some thin sheet aluminum and made little strips with holes for the retaining screws, and they sit over the pins keeping them in... I hope it works!
I also managed to find my dogbone, so all is well!
OH
ORIGINAL: MOVMX Racer
