dusting off the Mini-T and RC18t
MO
So my mini's have been sitting in storage for the better part of a couple of years. The wife and i had bought some property, sold the old house (took over a year) finally got moved etc. Long story short they have sat in a tub for alike 2 years now that things are finnally starting to get back to normal i have some time to play with them again AND i have property to run them on (can you say b1tchin track!)
so anyway i got them out and and started going over them and remember i was needing a few things before i put them up. SO i figured 2-3 years have pased sence these things came out the aftermarket parts have to be booming by now.
but allas all the "good" sites seem to have gone... WTH happend to one18th.com?!?!
So what im looking for....
anyone run lipo's with just a brushed motor? Ive already got reedies and am happy there performance with that just want more run time. what a diff 2 years makes in the lipo market. when the RC18t first came out they were still uber expensive and still cutting edge... now everyone seems to sell a lipo pack.
im tired of putting crappy stock stearing servos in my Mini-T i see they finnally released an upgraded stearing servo for like an HS55... but then i have to do a 3-4 wire mod... Nothing wrong with my stock electronics, why spend them money...
Ive worn down my second front pinion gear, it clicks under heavy bashing, looking at it in my hand its obviously worn. Stick to delerin or does someone make some AL gears yet?
IL
RE: dusting off the Mini-T and RC18t
ORIGINAL: schmism
ORIGINAL: schmism
ORIGINAL: schmism
MO
ORIGINAL: The Mad Modder Rc18 pinions also fit the mini-t. Robinson racing's hard anodized alum pinions have worked well for my baja.
ORIGINAL: schmism
you talking about the motor pinions or the diff pinions Im talking about the diff pinion attached to the central 4wd shaft
It's also called an input gear. Get this, and use the input gear with a plastic diff gear; that way everything still operates smoothly. I bought one for the rear of my RC18 since most of the weight is riding on it. Well worth the $14 to me. Make sure your diff is shimmed just right too. I assume you have already done this?
I wasted so much money on those stupid Mini-T servos. Just buy one with metal gears (JR 241mg), and move on. I gladly replaced all of my electronics to get rid of this problem.
IL
ORIGINAL: schmism
